Looking at EZ-Burr tool, have questions from those that have used them.
I am looking at purchasing one or two of the EZ-Burr tools.
I like the design of them better than the Cogsdill version. Seems less likely to jam up and make a mess. The two part numbers I have picked out are: for #30 holes - EZL0129-02 for #40 holes - EZL0098-02 extra blades - L1A-02 I don't see any way to specify rake angle on the blades. Anyone have any advice? Is the default fine for our use or do I need a zero rake blade if offered? |
Have you thought about something like this?
Admittedly you have to run it twice front and back to deburr, however it's cheap and low maintenance. In a pinch or for NAS1097 rivets on nutplates they make a great countersink cutter. |
according to the application chart L1A-02 is good for aluminum
http://www.ezburr.com/products/pdf/h...blade_info.pdf I use them, they are pretty good. You still need to be pretty careful because if it jams you will just ream out the hole. Hasn't happened to me but read that somewhere. Its easy to over do it by hand. When I run these on CNC machines at work its simple to dial it in just right and the tool goes in and out faster than you can see it. Doing it by hand on an aircraft skin is a different animal. I set the blade to just be barley potruding from the shank (approx .003) and go slow. This prevents the chamfer from being any bigger than about .003. I still go over it lightly with scotch brite and my burrs are minial to begin with as I ream everything with a carbide reamer. |
E-Z Burr
These come in very handy at times and work well.
Never had a jam problem. Gary R. Kohler RV-7A Flying at long last... |
I have a full set of Ez burr and love it. It is specially hand for holes that you have a hard access to the opposite side.
| All times are GMT -6. The time now is 11:00 AM. |
