VAF Forums
-   RV-14 (https://vansairforce.net/community/forumdisplay.php?f=109)
-   -   Fuel Drain Connection leak (https://vansairforce.net/community/showthread.php?t=166104)
didja 11-17-2018 11:43 AM
So..... apparently, I was an complete idiot and forgot to put proseal on the inside face of the drain valve flange plate before riveting to the skin.... or just a partial idiot and didn't put enough.....
Either way, I am hoping that someone may have an idea of how to seal this up permanently without cutting into the baffle...….
The leak literally comes from every angle of this flange plate, indicating to me that I was a complete idiot and not just a partial one!!!
I have the kit so that I can cut a hole in the baffle to get to the backside of this if I have to, but if there is something that someone thinks would work without having to do that, that would be awesome!!!
David Paule 11-17-2018 12:16 PM
It didn't look as if you'd filleted the edges of the flange. That would probably be worth a try.
You might try using the Type A tank sealant (you can get it from www.skygeek.com). This works the same but has a thick syrup consistency instead of a paste. Your choice.
Dave
RV-3B still building
rvbuilder2002 11-17-2018 01:01 PM
If there is no sealant, the only correct way to correct it is to remove the flange and reinstall with sealant.
I think there are some decent quality 3/32 flush blind rivets that could be used in place of the AN426's, that should be exceptable to use and would allow you to avoid opening up the tank.
didja 11-17-2018 02:58 PM
I had thought about doing the fillet idea around the edges, but that seems too temporary to me, and I think that I would be yanking the tanks off at a later date to fix it correctly.
One idea that had heard from a fellow builder at the hangars was to remove the fuel sender and access the back side through the fuel sender access hole and then re seal the sender and screw back in place.
I think that this will be the way I try to correct it, but if that doesn't work, then I will try the blind rivet method. I will have to contact van's to see if they make the solid blind rivets similar to the ones used in the Z-attach brackets for the tanks......
TShort 11-17-2018 03:30 PM
The rivets on the drain flange are countersunk; I know they make them, as we used one to seal a leaking rivet under the wing walk on my QB tanks.
I'll have to see if I can find the Spruce part number...
TShort 11-17-2018 03:36 PM
Couldn't find it on Spruce, but Google found this:
https://www.hansonrivet.com/rivets/b...-blind-rivets/
It would be the AK4_H (the _ depends on grip length, that flange is reasonably thick).
Spruce has the 43H, which I think is what we used.
T.
didja 11-19-2018 08:45 AM
Well, got the flange drilled out and pulled from the skin. There was a *very* thin layer of proseal between the flange and skin. It didnt take much effort at all to peel the flange from the skin.
The unfortunate part is that I cant seem to find a 3 series closed end sealing blind river (3/32 size) anywhere. I can find lots of 4 series (1/8 size) but that is so far as small as I can find.
I have two options, as far as i can tell..... pull the fuel sending unit and get access that way to be able to buck new solid rivets with the existing size, or confer with Van's to see if these would be ok to drill out to the size needed for a 1/8 closed end sealing countersink blind rivet.......
TShort 11-19-2018 09:34 AM
Here's another online resource, not sure if the grip length is enough for your application:
https://www.baysupply.com/2472182/Pr...osed-End-AK42H
Spruce has them too, I don't think the pic represents the actual product:
https://www.aircraftspruce.com/catal...lickkey=266960
Mel 11-19-2018 09:36 AM
You don't have to use "closed end" rivets. My biplane tanks are built exclusively with regular pulled rivets. Proseal will weal the stem hole fine.
didja 11-19-2018 11:30 AM
Yea, I actually just got off of the phone with van's tech assist and he stated the exact same thing.....just use the flush blind rivet, use lots of pro seal to hold the flange in place, and use a good amount around each blind rivet..... I think that this is how I am going to do the repair.
My understanding is that the shop ends of the rivets that were drilled out should not be a problem with the strainer being smaller than the drilled off shop heads of the old rivet......
