Fuel protection for Vinyl wrapping
I'll be wrapping using Avery vinyl film. Unfortunately, one needs to put another clear film on top of the vinyl where fuel may spill into the vinyl (fuel + vinyl = really bad).
Any thoughts on the best film to use for this protective layer? |
I'm toying with the idea of wrapping my wings, but fuel messing with the wrap would likely be a deal breaker. Is it the vinyl itself, or the adhesive that is vulnerable? Does this apply to all brands, or just this particular brand? Charlie |
3M says their wrapping vinyl is protected against gasoline (as long as its wiped off quicky). I would check with Avery but they should be the same.
My RV-7A is now over 3 years and about 650 hours into an all-over vinyl wrap job by AircraftWraps.com using the 3M airliner-grade vinyl wrap. I have spilled far more 100LL over the wings overfilling the tanks than I am proud of. Absolutely zero impact on the vinyl wrap.
As mentioned above, make sure you're using the right vinyl. The 3M aviation stuff scoffs at 100LL. :cool: |
EDIT FROM SCROLL: I’ll look next time I’m at the hangar. FOLLOW-UP EDIT FROM SCROLL: OK, it's the 3M 1080 airline-grade line of vinyl film. |
I have an automotive grade of 3M vinyl on my wings - and I can assure you that it easily stains and will dissolve under prolonged contact with 100LL.
I asked aircraft wraps once what their special trade secret product was. They brushed me off.
Six years and 500+ hours now on my 3M 1080 colors and Avery Conform Chrome. While I have polished aluminum on top of most the wings, fuel spills have happened fore and aft to the vinyl with no adverse affect. I would seam seal arround the fuel caps for sure to help keep fuel from seeping under. As always YMMV. PS: Cast vinyl is what you want, and the best grade and brands plays into it as well. calendared Vinyls you do not want. And pre colored solids will last longer than custom printed in most cases. Custom printed graphics add another variable based on the quality of the inks and such. I have lots of the 3M 1080 in the Hangar, I’ll slap some on a sheet of aluminum and fuel test it, with the seam sealer, and without. |
May I ask what the expiricend builders put under the vinyl? Is corrosion protection needed or can the wrapping take place on bare aluminium?
| All times are GMT -6. The time now is 05:53 AM. |
