VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   electronic gremlin advice (https://vansairforce.net/community/showthread.php?t=166065)
Jmason 11-16-2018 04:39 AM
so i went to start the RV-6 yesterday after some much needed maintenance. (replaced #4 cylinder) and for some reason at idle i'm producing 30 amps where i was producing 7 amps before in the same configuration. I'm thinking that it might be due to the cold weather that moved in but i'm not sure. Any thoughts?
dlloyd3 11-16-2018 06:24 AM
Could be battery was discharged during maintenance and the amps to charge will drop off in a few minutes. How long did you see the 30A?
Could be a battery problem. A dead cell will cause a high amp draw.
A loose and arcing connection could cause a high amp draw.
A loose or corroded connection in the sensor circuit could cause a high amp draw indication.
maniago 11-16-2018 08:04 AM
If youre not seeing smoke or sparks, thats a good thing, and I'd tend to agree with the battery charging. In reality tho, 30A is a heaping amount to be going stray somewhere otherwise. I'd thro the battery on the load tester and then the charger and see what it says before going any further, both cheap money at Harbor Freight if you dont already have them, battery type depending of course....
Jmason 11-17-2018 03:29 PM
battery
Thanks for the advice. Turns out it was the battery. I did a slow charge over night and it solved the issue thank you both
