B&C alternator brushes
Does B&C sell brushes for their alternators? (mine is the standby alt)
Or must one send it in, for this simple repair? I see none on their alternator parts link. http://www.bandc.aero/alternatorreplacementparts.aspx |
However I did get a helpful pm saying B&C will not sell parts. If your ($2) brushes are worn, you must send it in for overhaul. |
Pull out the brushes, go by your local automotive alternator/starter repair and tell 'em you need some brushes for your airboat. They will fix you right up for just a few dollars.
What makes you think it needs new brushes? B&C recommends OH at TBO, I sent my 40A alt in at 1500hrs for a check-up, turns out it didn't really need anything and was working fine when I removed it for some other work. I had them do the full treatment anyway as long as it was there.
By the time the brushes are worn out, the commutator may also need to be cleaned/trued up, and the bearings should be inspected carefully or just replaced as preventative maint.
This is assuming the brushed did not have some kind of early failure. |
upon pulling the brushes, can see the shaft is wobbling.
Sent to auto alt/starter shop. |
final follow up
new brushes new slip ring new bearings new aft housing Auto shop matched it to a Denso model. $220 working like a charm now. |
George |
1002114100 or4103 or4104 I can give you his contact info if desired. El Paso TX PM me for that |
| All times are GMT -6. The time now is 12:58 PM. |
