VAF Forums
-   RV-7/7A (https://vansairforce.net/community/forumdisplay.php?f=7)
-   -   Nuts and washer on inner tube? Use or Lose? (https://vansairforce.net/community/showthread.php?t=165927)
KiloFoxtrot 11-11-2018 01:29 PM
RV7A build
Does anyone know the purpose of the Nut and Washer at the base of the inner tube stem closest to the tube?
The inner tube comes with 1 nut and 1 washer at the base of the stem and 1 nut beneath the valve stem cap. I have read in the Matco instructions that nut/washer at the base of the stem stays on and should be placed in the slot on the rim when mounting.
Would anyone know how tight the nut at the base of stem should be when installing?
As for the nut at the end of the stem near the valve stem cap I need to know If and How I should use that.
Larry DeCamp 11-11-2018 04:52 PM
Same question 😒
I have Grove wheels and Michelin tubes. More hardware than places to put it.
rvmv 11-12-2018 03:20 AM
holds the valve stem in place
Take a look at this
http://www.smittysrv.com/more_stuff....729&Section=68
KiloFoxtrot 11-12-2018 07:24 PM
RVMV.....Thanks for that link. That explains what I needed.
