gross weight increase ELSA
Can anyone tell me / reference me the steps to recertify an ELSA compliant RV9-A to Vans recommended gross weight of 1750#? With Basic Med I no longer need ELSA compliance and potential purchaser wants it certified higher
Thanks Tim RV 9-A N932WF, ELSA compliant gross weight 13230# |
No problem. Since the aircraft is certificated as experimental amateur-built, you may place the aircraft back into phase I and test the aircraft to the new gross weight. The process is listed in you operating limitations. Depending on when you op lims were issued, the latest version, this would be paragraph 14.
What Mel said.
Just keep in mind that once you go up, there is no going back down. |
Mel, I've often wondered if this process applies if you are not the builder of the aircraft. I assume so, but have not found anything that justifies it.
Any further news on this original subject?
We should get a pool going. Of course we could all be dead by the time the results are known.
| All times are GMT -6. The time now is 04:41 AM. |
