Crankshaft differences
I am looking at a lycoming 13B27120 for $6,000 verses a Superior SL-36500-A31 at $4,000. Does anyone have experience with the differences and is it worth it?
They both are setup for a constant speed propeller and are non-counterweighted.
Only difference is the manufacturer |
The Superior crank is equivalent to four different Lycoming part numbers including the one you list.
Details here - https://web.archive.org/web/20150919...L36500-A31.pdf |
Crankshaft
thanks Gil, that is good information. Superior is changing vendors giving a 2 year leadtime and no one stocks the item so it looks like I will have to go with lycoming.
ECI crank
I might have a ECI crank in the same configuration for around 4800.00. Save you a bit and they don't have the AD if you convert to fixed pitch. You can call the shop if you have any questions. I haven't been on the computer much lately.
Jesse 970-874-7575 |
O-360 crankshaft
The Continental "Prime" aftermarket crankshaft equivalent to the Lycoming 13B27120 is part # AEL36002-1. It has a robust solid flange that is .44" thick, 1/2-20 thread flange bushings, and is set up for constant speed propeller operation. Aviall have them in stock. They are a more affordable alternative manufactured and backed by OEM Continental Motors.
Agreed.
James is correct. We have had good luck with the AEL cranks and I specified one for my personal engine in our 8 and it has done very well.
Yours, R.E.A. III # 80888 |
| All times are GMT -6. The time now is 04:56 PM. |
