VAF Forums
-   -   Fuselage quick build items to Delete (https://vansairforce.net/community/showthread.php?t=165059)
Piplnr65656 10-14-2018 01:00 PM
Hi, We are ready to order our fuselage quick build kit. Wanted to double check which items may be a good idea to delete from the kit and go aftermarket. So far we were thinking:
1. Windows, delete factory and use Cee Bailey.
2. Fuel valve, delete factory and use Andair. Is this still the best route to go?
3. Fuel and brake lines. We figured we should upgrade to the stainless steel braided lines but we are not 100% sure which items to delete from the kit.
Any other items we should consider changing out?
rocketman1988 10-14-2018 01:54 PM
And
Brakes, wheels, tires, cowl, spinner
ADD
VA-186 oil cooler mount
Baffle kit
VA-187 4? SCAT flange for baffle kit because it?s not included
mciaglia 10-14-2018 06:47 PM
I think rocketman is referencing the fishing kit...that?s where the cowl, spinner and wheels are
I deleted all the rudder pedal assembly as I installed the control approach pedals
Defiantly the windows if your planning CeeBaileys
There is a complete list of items deleted on my blog
Aircraft Specialty 10-18-2018 11:18 AM
Disregard...PM sent to OP
