Measuring prevailing (running) torque for nylon lock nuts
AC43.13 talks about nylon locknut "prevailing torque" which is the torque from the locking mechanism that must be overcome when attaching them to bolts. This amount must be added to the specified torque value for the bolt. I've found empirically, that simply tightening a nylon locknut to the bolt's specified torque is insufficient (the torque wrench "clicks" before the bolt even snugs down). How can I measure this extra torque that will be needed, both to get the bolt snug, then to tighten it properly? Is there a special tool needed to do this, or is there a rule of thumb given the fastener type + size? Is this value going to be different for each individual lock nut??
The most accurate way is to purchase a dial style torque wrench but the following is close enough....
Incrementally adjust your torque wrench to find the torque value where your torque wrench just "trips" when turning the nut on the end of a bolt, but not yet in contact with the washer. This is the prevailing torque value that you should add to the spec'ed torque value. For the spec'ed value, use the center of the range to allow for slight variation from one nut to the other. |
Prevailing Torque is a Measure of the Effectiveness of the Lock
It?s really a check to make sure the ?lock? is within specification. Typically, the fasteners are test to a specification for ?first on? i.e., is too much torque required to run the nut down. Next test is ?first off?- is the specified amount of lock or prevailing torque still present. Last element is ?fifth off?, where prevailing torque is measured after a fifth re-use to see if the lock is still within a specified range. The same type of test are done for both nylon as well as all metal locknuts. These are SAE or IFI standards. The application torque is spec?d for The joint and/or the fastener system. You need not add prevailing torque to it.
Terry, CFI RV9A N323TP |
The torque value in most charts referenced by RV builders is for a plain nut. If a self locking nut (or nutplate) is being used instead, the prevailing torque is measured by the torque wrench and will cause the actual torque of the nut to be below the desired value if prevailing torque is not added. |
Too, most torque wrenches have increasing errors toward the edges of their range, so your measurement is likely to be doomed from the outset absent mucho$$$$ gear. Just use the values recommended in the Van's manual: clearly those ten thousand aren't falling out of the sky from undertorquing. |
I agree with Scott, with the fine tuning that you would like to know the torque required while turning, not to just get it to start. That much I kind of agree with what Aluminum said. HOWEVER-- The AN fastener torque spec is already on the low side of normal engineering practice. I've written about this before. The slight overtorque from following Scott's advise exactly (which may result in measuring the 'stiction' torque rather than the running torque) is far better than substantially undertorquing by not adding in any correction at all. An in-between approach, what I do, is to use a flex-beam type torque wrench. Not as accurate as a dial type, but they are pretty good, and with that, you can see the needle on the scale while the nut is turning, giving you a running torque measurement. |
I agree that the prevailing torque of an AN365 10-32 nut is not very high and wont have a very large influence, but the OP's question was general in nature and we should not ignore it for all fasteners. Additionally, the newer RV kits use other style of self locking fasteners like all steel MS nuts, etc. which have a much higher prevailing torque than a nylock nut. |
Anyhow, there are by now hundreds of RVs flying with MS nuts, and those don't seem to be falling out of the sky from under-torquing either, so the ancient wisdom of 28 in*lbs for AN3s appears to work just fine. :cool: Don't fix what's not broken, and all that. Bonus: these torque adapters are great for the bigger bolts (too coarse for the 10-32s) and more versatile than a wrench. |
| All times are GMT -6. The time now is 12:17 PM. |
