VAF Forums
-   -   Extra fuel in the wing tips 🛫 (https://vansairforce.net/community/showthread.php?t=164907)
Toobuilder 10-14-2018 10:29 AM
Originally Posted by RWoodard (Post 1295334)
I?m thinking I can enclose the space in the wingtips and make a composite tank. Shouldn?t be more than about $50 in fiberglass and resin (have most of it on hand anyway), another $150 for some Jeffco sealant, a couple of fuel caps, some fuel line, etc...
I'd take a good look at how the shear load of that new tank is addressed. The L-39 uses a similar attach method for its 26 gallon tip tanks, but the fasteners going into the upper and lower skin are large, numerous and in double shear. In addition, there is a hefty lug that ties the Tank into the main spar.
airguy 10-14-2018 04:21 PM
The L-39 is also designed for significantly higher aerodynamic loads.
I know you know that, I'm just sayin... sometimes overkill is appropriate caution, and sometimes it's just overkill.
Toobuilder 10-14-2018 06:43 PM
Im not suggesting a copy of the L-39, but hanging a wet tip off a bunch of #8 screws countersunk into fiberglass will take some careful study.
RWoodard 10-15-2018 09:44 PM
I've seen several load tests at fly-ins when uncaring/unaware parents use wingtips as baby changing tables! Those chubby infants with a full diaper have got to be pushing the weight of 5 gallons of 100LL!
:D
Bullseye 10-16-2018 06:24 AM
[Looks over at my chubby infant....calculator sounds in head...] Yup.
BobTurner 10-16-2018 11:13 AM
:D
They?d need to be really chubby:
5 gal gas = 30 lbs, at 3.8 g = 114 lbs.
Bill Boyd 10-16-2018 11:17 AM
Airliner-gentle? Some dim memory is stirring as I read this
whether it was here or on the Matronics list, I don't recall... a certain airshow RV pilot was stating that adding fuel capacity to the wings had no penalizing effect on aerobatic gross weight and might even lessen stress in the spar by bending it the other way when pulling G's - and Van's be darned if they disagreed with him. I was not so sure I agreed with the aerodynamix that were being propounded, but nevertheless, there it was.
Anyone else recall that?
rv7charlie 10-16-2018 11:50 AM
Don't recall that particular thread, but there are multiple issues; not just wing bending moment/gross weight. Yes, spreading the load out along the wing can reduce the bending moment at the root, *but* spin characteristics and control effectiveness can change radically. At least for me, that's the reason to keep the plane as close to stock as possible for acro.
edit: Not meant to say I wouldn't add aux fuel; I'm doing that on my -7. Just that I made every attempt to keep added weight to a minimum, and kept the ability to fly with fuel in only the original tanks when flying acro.
paszekj 10-20-2018 07:19 PM
I'm just getting started so maybe I'm way off base here but my understanding is the HW Aviation tanks function by pumping from a small auxiliary tank into the main tank via a bung in each main tank. They even sell the bung kits separately that you can install when building to make it easier to add extended tanks in the future if you so decide.
Would it be possible to install an additional bung in each wall of the fuselage with a hose leading to each main tank, then have a removable additional tank (like an RV12 tank?) that you could secure in the baggage compartment with a single pump and a fuel selector switch? Then have a hose leading to each of those bungs in the fuselage wall. You could install the tank and hoses when needed for long trips, then remove it if you don't need it or want to do aerobatics/spins. It would have the additional benefit of being able to visualize a volume gauge in the tank while flying to verify that the fuel has transferred to the mains.
Maybe there are factors I'm not considering but I would think it would be lighter and cheaper than two separate tanks plus the benefit of being able to remove it. Granted you would use up most of your baggage capacity with a full tank but maybe a vertical tank right behind the seats (e.g., like a briefcase shape right behind the seat) would help keep the COG a little more forward. crazy?
rv7charlie 10-20-2018 07:45 PM
What's the mission? If you're just doing solo distance record stuff, sure. But if you're doing it to tanker fuel and/or for travel with a friend, then as you said, you lose both baggage volume and payload, because all the bending loads are in the center of the airframe. You're also riding around with a lot of gas in a temporary, removable container in the cockpit with you. Even without fire, a leak could be overwhelming. And depending on your alternate choice of built-in tank 'method', it can be significantly heavier. My two leading edge aux tanks added around 30 gallons capacity at the expense of about 2 lbs additional weight (probably around 4 lbs total, including fuel lines).
Your choice on plumbing. Mine is (was, at the time) a bit of a special case. I knew I was going to be using automotive style injection, so the engine is fed from only one tank (ala turbines). The other three tanks are all aux tanks, and the fuel selector just picks which one transfers to the main. Downside: no backup tank (but *many* a/c have only one tank, or a header that's fed from selected tanks). Upside: no switching tanks and no need for a duplex fuel selector.
If you want behind the seats tanks, here you go:
https://www.smokingairplanes.com/products/
His tanks can be plumbed as aux tanks.
