What happened to Van's engine gauges
Folks,
A friend just had an overvolt and fried all his stock engine gauges. The Van's web site shows them as no longer available...What gives? Thanks, Tim |
Did you try asking Vans?
Chief aircraft
I believe Chief has exactly the same instruments without the RV logo on them.
Steve |
On behalf of the traditionalist here, I bought the Van's engine gauges a few months ago, to go along with the new steam VFR gauges going in my -6, I think they are the same as the Chief gauges, don't give up the fight, build the airplane you want.
If anyone is interested, I do have several Vans gages that I did not use in my build. New and unused in the box: tach, fuel pressure, ammeter, CHT, EGT, and a fuel primer.
Vans guages available
I have two fuel level guages and a voltmeter with 10 hrs on them on the shelf.
decamplarry@gmail.com 765-505-1160 Larry also, an MGL RV-1 tach and Gmeter if interested. |
| All times are GMT -6. The time now is 12:36 PM. |
