VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   Remove the rear inner cap from the crankshaft (https://vansairforce.net/community/showthread.php?t=164736)
filiperosa 10-03-2018 02:54 AM
Hello,
I am changing my crankshaft from a CS prop to a fixed pitch prop. I should make a hole or remove the inner centre cap. I do not have a so long drill to make a hole on it.
Can someone advise me on the easiest and best way to make it? I try to push it forward from the front but it did not move. I did not apply much force afraid to damage something.
Filipe
rvsxer 10-03-2018 06:18 AM
Filipe,
Don't drill it, the drilling debris is too hard to remove completely. Take a long, sharp-pointed punch and put a hole in it. You can then use a slide-hammer with a threaded end to pull it out. It should come out easily. Be careful to avoid damaging that oil-transfer tube that extends across the opening. Some people just punch a hole in the plug and leave it in but I prefer to remove it.
guccidude1 10-03-2018 09:34 AM
I agree with the previous post. One word of caution, if you damage that oil tube, the crank must be removed and sent in for repair. I did all the prep work for removal of my inner cap and hired the local mx dude to remove it and set the outer cap. He had made some "special tools" to remove it with his rather small slide hammer. Dan
filiperosa 10-03-2018 10:20 AM
Thank you!
I just punched a hole. Tried to remove the cap but was stuck so I decided to leave it like that. Do not want to damage anything.
Mel 10-03-2018 10:45 AM
You don't have to remove it. You just need a hole to relieve pressure.
rvsxer 10-03-2018 01:10 PM
That hole is fine. The oil transfer tube looks good so you are good to go.
az_gila 10-03-2018 01:29 PM
However it looks like the paint is too thick on the prop drive lugs.
They are usually not painted.
filiperosa 10-03-2018 01:58 PM
Thanks guys!!
Yes, it is epoxy primary but It is very easy sanded down. However, I decided to apply because it protect it before I use the engine.
mahlon_r 10-03-2018 06:42 PM
Also no paint on the front of the crank flange!
Good Luck,
Mahlon
blueflyer 10-03-2018 06:46 PM
I would be interested to see a photo of the tool(s) you used to punch that hole.
