VAF Forums
-   RV-3 (https://vansairforce.net/community/forumdisplay.php?f=10)
-   -   RV-3 Instr. Panel - Solid Works model or STEP ??? (https://vansairforce.net/community/showthread.php?t=164280)
N329JR 09-17-2018 01:02 PM
Does anyone have a STEP file or Solid Works model of the instrument panel for the RV-3?
Ian
RWoodard 09-17-2018 01:58 PM
I?ll be following this thread.
I?d like to install a new panel in my new-to-me RV-3 this winter.
I?ve asked my smarty pants Aerospace Engineering niece to draw it up for me in AutoCAD and/or Solidworks, but it hasn?t happened so far.
I?ll definitely share if I end up with the file.
David Paule 09-17-2018 06:22 PM
Before using, verify that it fits your fuselage. The panel outline in the plans, for example, isn't as wide as my fuselage.
Also, do you want the panel to go to the external side skins or is it inset to allow the removable cover between the panel and firewall to sit flush to the sides? By the plans, the panel should be flush to the side skins but I've seen at least one that had that cover flush and the panel inset.
More, some panels have a slight bit of extra height over what the plans say. Usually, that's below where the plans have it but it might not be.
Be careful here.... this is an RV-3, and they often differ from one another.
Dave
