Custom/non-standard throttle quadrants?
I?m currently planning on a center console-mounted throttle quadrant (the console is partly to hide extra wiring, plumbing, and EFI fuel pump etc.). But using EFI, I have no need for a mixture lever. I just need throttle and prop.
Is there anyone out there that makes appropriate quadrants to order, without a mixture lever and preferably with a blank face plate? |
Could you just use a two-lever (fixed-pitch) quadrant and repaint the mixture lever? Might be easier, and almost certainly cheaper, than a custom quadrant.
While I do not advocate center console quadrants, you could use the extra control for your oil cooler air butterfly valve. I did that on my first RV-8A and it come in very handy when I back fitted a CS prop.
Carl |
I'm still at least 2 years off, but have also been wondering the same.
I was thinking there may be an easy way to just remove the mixture lever off the throttle quadrant and maybe I would make a fiberglass plug for the mixture slot? (I don't like the idea of using a mixture knob for some other function so I don't develop a weird muscle memory if I fly a different setup and pull the mixture accidentally) The idea of using a 2 lever quadrant (fixed pitch) and trying to change the knob / modify the label also sounds like a possibility. Maybe this will become more of a thing as more people start using EFII systems? |
Aerosport Products produces a two lever throttle quadrant. Mine will be arriving Thursday and will post some pics
Make your own..
When I built my -4, I didn't like the market available quadrants and wanted a slim 2 lever that would hide in my side panel. I made my own from some scrap aluminum and used 1/4" phenolic sheet I cut for the friction plates. Mine has worked perfectly and I made my knobs from round tubing filled with epoxy that screw onto the levers. The key is getting the lever geometry correct for the cable travel.
The only other airplane I'd be flying would likely be Dad's 6, and that has push-pull knobs on the panel. Quote:
I forget who makes the throttle quadrants that Van's and ACS sells, but why not just call them and have them change the knob on a 2-lever quadrant?
They're easy to disassemble and reassemble yourself, as well, if you want to swap out a lever or knob. There's not much to them... |
Give DJM a call - Dayton makes the Deluxe throttle quadrant that ACS and Van’s sells, and can probblay come up with a solution for you.
Paul |
| All times are GMT -6. The time now is 04:26 PM. |
