Dynon Skyview 15.3.4 Release
FYI: Looks like Dynon just released software version 15.3.4 for Skyview systems on 9/13/2018.
Thanks. Easy to miss. From the release notes:
New: New more descriptive percent horsepower ?%HP? widget. Improved: Engine monitoring widget display pointers (?needles?) and textual labels are now higher contrast / brighter. Improved: Default text label size for EMS widgets increased for widgets on 50% and 100% screens. Updated: TRAFFIC FAIL indication is now a yellow caution alert. Fixed/Changed: HSI FPL SYNC now appropriately considers serial aviation devices. TIE FLIGHT PLAN SRC TO HSI NAV SRC moved from ARINC to MAP SETUP. Fixed:Dismissing a message on one display no longer closes the message window on another screen if it is being viewed. Fixed: A bug that caused ARINC to occasionally drop out. Fixed: ADAHRS could improperly use its calibration tables in very unusual circumstances. |
Hmm, I missed this one. I updated the September data base, but now I notice in the 15.3.4 release, it says to update the new release BEFORE you update the data base. Wonder what will happen?? Hope my D1000 doesn't self destruct.:eek:
The software release I used for US contains the latest 9/13 database.
Flew to Reno with new maps but old software, didn't die. Guess it'll be mostly all right.
| All times are GMT -6. The time now is 02:39 PM. |
