VAF Forums
-   RV-9/9A (https://vansairforce.net/community/forumdisplay.php?f=5)
-   -   RV9a VOR/ILS Antenna location (https://vansairforce.net/community/showthread.php?t=164072)
whd721 09-10-2018 07:00 PM
Does anyone have have any Photos or installation guidance on the installation of a Comant CI-157P antenna on an RV9A?
Where, how and advice.
BMW_X6M 10-10-2018 07:25 AM
I have the Bob Archer in the right wingtip. It has great reception of both VOR?s and ILS transmissions. It is easy to install.
Carl Froehlich 10-10-2018 08:00 AM
Friends don't let friends stick ugly VOR antennas on their nice RVs. Put it in the wingtip. Either buy the Archer antenna or build your own.
My wingtip antenna picks up VORs at 100nmi and the ILS out beyond practical usefulness.
Carl
airguy 10-10-2018 09:02 AM
Same here - built my own Archer-style (one in each wingtip so I have a backup - they weigh nothing) and the reception is excellent on both VOR's and ILS.
lr172 10-10-2018 10:01 AM
I have one (archer wing tip) that I am about to sell, so PM me if you go this way.
Larry
dcl 10-10-2018 03:30 PM
VOR/ILS/COM
Are these the two antennas for the wingtips ? I think 1 is com and 1 is VOR/ILS
https://www.aircraftspruce.com/catal...r_antenna1.php
https://www.aircraftspruce.com/catal..._antenna-1.php
David
BillL 10-10-2018 03:42 PM
David
Yes, the VOR/ILS is mounted horizontally and the com vertically. No personal experience with the COM, but IIRC, it is not stellar. The VOR/ILS is excellent.
rolivi 10-10-2018 03:44 PM
I think if you search this site for Archer you'll find that the NAV gets generally positive reports but the COM does not.
For that reason I use belly whips for my COMs and the Archer for my NAV.
YMMV.
gmcjetpilot 10-21-2018 07:38 PM
With an A model your tail is high. I like putting a di-pole twin whiskers on top of rudder under tip fairing. This is a great location and drag increase is tiny (fraction of a mph). The thin metal rods are not noticeable. Performance for VOR, LOC, GS I think will be better than the wing tip antenna.
The other place is under the horizontal tail on the belly. The Horizontal stab covers it so it's less obvious. You have to be careful not to poke your eye if crawling around under tail say for tie down. I had my RV-4 under belly/horz stab. It worked great. xxxx = VOR/LOC/GS antenna. (you can get a split-coupler to do all three). See links. No offense to internal wing tip antenna but it's a huge compromise. I suppose it is academic with GPS but for such little penalty in drag the standard dipole out in breeze is going to give better performance.
https://goo.gl/images/XKiWEp
https://goo.gl/images/pwmfds
.........................____
......................./xxxx|
___________/.............|
_____________________|
......................xxxxx
https://goo.gl/images/bCRRSs
https://goo.gl/images/Q4q9Hd
whd721 10-21-2018 08:56 PM
Thanks to all that replied.
In the long gap between my original post and today, I had come to the same solution posted by gmcjetpilot above.
I now have a Comat 157p and plan to mount it on the rudder. I was pleased to find the current model has a hockey puck that is only about 1/4" thick. It should be nearly invisible way up there.
Thanks again.
