VAF Forums
-   RV-14 (https://vansairforce.net/community/forumdisplay.php?f=109)
-   -   QB Shipping Options (https://vansairforce.net/community/showthread.php?t=164020)
ZachMiller 09-11-2018 02:17 PM
I quoted renting a truck to drive a kit from Oregon to Texas and it was around $1000 and over 20 hours. Not worth it in my opinion.
Also, I'm in Caddo Mills building an RV-7. Probably an hour from Tyler. I'm planning on flying there for lunch this weekend, actually.
Ironflight 09-11-2018 04:58 PM
Originally Posted by Bavafa (Post 1287753)
One other idea would be just to rent a one way U-Haul and take it yourself. You get to see the country side and might save a few $$$. This is what I did, though my distance is not nearly as far as yours and it worked great. I got all the kits, including finishing kit and did not need any crating which saved $$$ .
This might work out for some, but when you count the rental, the gas, and time to drive it yourself (including one way transportation to get in position) the percentage saved is small. I have a kit coming from Wisconsin later this month, and I did the math - far easier to let Tony do it. Maybe a few dollars more - but I?d spend those buying material to build support structures in the rental to make sure nothing shifted on the way....
