VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   Vernier-Assist Throttle for RV-12 (https://vansairforce.net/community/showthread.php?t=163959)
mclark.whidbey@gmail.com 09-07-2018 02:14 PM
Anyone have experience with the 912/914 Vernier-Assist throttle control for the RV-12, available from A/C Spruce? If so, what size is appropriate as a replacement for the stock "creeper" throttle control?
Thanx,
Mike Clark
N712WE
DaleB 09-07-2018 02:26 PM
Thanx,
Mike Clark
N712WE
I installed one bought directly from McFarlane. Van's sells them also. Pricey, not hard to install, and worth every penny. I've had NO throttle creep whatsoever since installing it, and power adjustments are effortless.
This is nothing like the pushbutton-release vernier cables found on typical production airplanes. You just push or pull like a normal throttle, there's really no difference except that you don't have to crank the friction so tight it's hard to move. For fine adjustments, just twist. Effortless.
Just one guy's opinion.
Handclutch 09-07-2018 06:32 PM
Couldn?t agree more - vastly superior to the original. You can make small changes by twisting the knob (vernier assist) but it is so easy to use I seldom use that feature.
Jack
randylervold 09-07-2018 06:50 PM
Jack
Don't even THINK about any formation flying with a vernier throttle. Also, I find micro throttle adjustments on landing any aircraft difficult with a vernier throttle. Food for thought.
DaleB 09-07-2018 07:03 PM
As stated, this is NOTHING AT ALL like a typical vernier throttle. Does not operate the same way at all. There would be no difference whatsoever flying with this or a regular throttle cable.
Mark33 09-07-2018 10:08 PM
That is correct, and as you stated they are specifically referred to as ?vernier assist?. It?s the best throttle cable you can buy.
Mark
maniago 09-08-2018 05:15 AM
Id like to do formation and Ive been wondering about if the McFarlane "vernier assist" is still considered vernier for formation because it uses the forbidden word, or if the guys have actually figured out that its not the same as the hated production version........???????? Maybe it should be called "twist assist" instead...???
mclark.whidbey@gmail.com 09-08-2018 03:09 PM
Great... but Van's catalog only sez:
VERNIER THROTTLE-12 CT THROTTLE CABLE-12V
If it is the McFarlane "vernier-assist" version, its certainly lacks that important detail. I'll give them a call next week for confirmation.
Thanx,
Mike
Mark33 09-08-2018 03:35 PM
Thanx,
Mike
If Vans doesn?t have the ?vernier-assist? you can order it directly from McFarlane.
Mark
DaveWelch 09-09-2018 04:14 PM
Bought mine directly from McFarlane. Good folks. At the time 10% off for EAA members. Soooo glad to get rid of “the creeper”. May be less of an issue now with latest return Springs.
Mitch757 09-09-2018 04:51 PM
I bought mine from Vans and it is the McFarlane product. Price was $215 a couple years ago.
Mitch Garner
N2ET
randylervold 09-21-2018 03:21 PM
Thanks for pointing that out Dale, sorry for assuming. Is throttle creep a problem with the fuel injected iS, or only the ULS?
rvbuilder2002 09-21-2018 05:02 PM
iS is totally different, and the iS airplane has a totally different style throttle control as well.
Bdalporto 09-21-2018 05:49 PM
I'm building a 7 and have been looking at the vernier assist cables and have been wondering about formation flying. I have flown and didn't like the old pushbutton vernier throttle. Randy, have you looked at the https://www.mcfarlaneaviation.com/ar...sist-controls/ type cables and do you think that would be accepted at a FAST course?
Brian
randylervold 09-22-2018 09:09 AM
Brian
Brian, I don't know. I've never had chance to put my hands on one, but the McFarlane site says "Coarse adjustments are made by pushing the knob inwards or pulling the knob outwards. Fine adjustments are made by rotating the knob clockwise or counterclockwise." When formation flying you will be making constant fine adjustments so if this throttle impairs that ability in any way then it would not likely be allowed.
Personal opinion: over the years I've learned that the throttle is your friend in landing any small aircraft in that you can make tiny little adjustments on short final to adjust your glidepath and touchdown point while still carefully managing your energy so as to not extend your rollout. I've found throttle micromanagement even more useful in the roundout and flare where tiny little adjustments can make all the difference between a smooth and short touchdown versus dropping in our floating way down the runway once you learn to use it. I discovered this while flying quite a range of aircraft from RVs to Cubs to Bonanzas.
Just my own opinion and technique, YMMV.
philrisl 09-22-2018 09:51 AM
The Mcfarlane throttle feels no different than any friction push/pull throttle. The friction is adjustable. When there is any friction set, twisting the knob makes fine adjustments. I have one in my Rotax powered airplane (Rans S19) and there will be one in my current project RV9.
Mark33 09-22-2018 09:56 AM
I haven?t installed one ?yet? in the -7 that I?m building, but I can tell you it?s definitely the one I?m going with. I did get to play around with the vernier assist a little bit while I was at Oshkosh this year and I can tell you it?s as smooth as butter. I think when the say that ?coarse adjustments are made by pushing the knob inwards or pulling the knob outwards? may not be the best description. It?s as smooth as any standard throttle cable with the locking nut and I don?t think you?d have any problem making those fine power adjustments on landing as you described. I just think that this throttle cable gives you the best of both worlds without any compromise.
Mark
randylervold 09-22-2018 09:57 AM
There we have it, thanks for the confirmation!
BruceEicher 09-22-2018 10:11 AM
Hey Randy,
Any better recommendations over the stock quadrant in the -8 (2 lever)?
And, looks like your signature could use some updating. :)
You in Seattle now?
Cheers!
