No, that would not be an issue. To install the exhaust, the nose gear (portion in the picture) need to be removed to accommodate the installation of the tail pipe. It is actually pretty easy but will require to lift up the front of the plane off its nose gear. |
Just confirm that the bushing is just slightly longer than the more in the strut so that you know for sure that the clamping force is on the bushing and not the strut end. |
isn't it easier to just put in place now? Or will it be in the way? I will have to find an engine lift at some point, but I don't think that I will be able to have it around for a long time. Unless the local EAA has one.
I don't know what the timing is between mounting engine and putting on exhaust system. |
It is also possible that there is a very slight variation from one system to the other that makes some fit and others not, but I have not had to disconnect the strut to install 3 different systems on an RV-14A. |
Think outside the box.... Add some weight to the tail and push the tail to the floor....lifting the weight entirely off of the nose gear and allowing you to do whatever you need. |
yeah, I know I can push down on the tail. I was just being a pain. Also, I would not have to take anything apart. Although after building this long, I am used to putting it on, taking it off, repeat, repeat, repeat. I am really looking forward to the cowling. I understand that require a lot of repeating.
Gentle fiddling allows it to be installed from the forward or engine side, without much trouble. In my case I had to do it twice! |
| All times are GMT -6. The time now is 05:06 AM. |
