RV-4 engine mount question
All,
Looking for real data from someone that has converted an RV-4 long gear from conical mount to a Dynafocal mount. Specifically, did the prop flange end up in the same place? meaning no cowl mods were done. The vertical and lateral offsets were the same. In the process of this prop swap I am evaluating the possibility to swap out engine mounts. Thanks for any help you can provide. |
Hi Axel.
Do you already have the Dynafocal engine mount? I'm asking because I have one and am about to chop it up to fit a Mazda rotary (Renesis). So it doesn't matter if I start with a conical or Dynafocal engine mount. However, no clue if I have the long gear. How can I find out? Finn |
I talked to AX-O today about this and could not give him an answer, however the gear legs have no impact on the position of the crank flange regardless the engine type the mount is made to fit or the length of the legs so anyone who changed from conical to dynafocal or vice versa regardless the gear legs, how did the crank flange match up, did the spinner end up in the same place, if not then how much did it change?
Would measurements from the firewall to the Spinner bulk head answer the question? Maybe someone with a Dynafocal could measure this on thier RV4.
Good move upgrading conical and go dynafocal, good .... I would only suggest conical if you had a wood fixed prop.
If you stick with conical get LORD mounts. They cost more but will be far superior to the original rubber bushing design. The dynafocal will transmits so much less vibrations and sag less. As far as engines I am 99% sure the conical vs dynafocal does not change the engine crank flange psition up/down, left right. The big difference in the cowls was, LONG COWL for a fixed prop with prop extension (or HC-F2YC Hartzell CS extended hub). The SHORT COWL is for a Compact hub Hartzell, which is now the standard. Van I recall longer offers LONG COWLS...They are all the same length. Fixed pitch props still need a prop extension, but shorter, to match the same dimension as a Hartzell Compact Hub CS Prop. |
I do have a source of truth data saying that the change from a short gear/mount to long gear did not require cowl mods. |
Axel,
I am not sure what might happen for your swap but I can tell you several years ago I converted a RV4 short gear to a long gear. Both Dynafocal. Everything changed, some things you would expect some not. I had to completely redo the baffling and ended up purchasing a new cowl and spinner as the old cowl was so far off it wouldn't even begin to go back on, and in such bad shape it was easier to replace. It could be easy then again it could be a giant can of worms. Ryan |
I have to ask, how do you swap out mounts without changing your crank case? I feel stupid asking the question, but you only said you are doing a prop swap.
Conical to Dynofocal change RV-4
The prop flange and spinner are in the same place within what I consider normal manufacturing tolerances. With the new dynofocal setup the prop flange was maybe 3/32" closer to the firewall. I did not change the cowling, although the new clearance to the spinner is less than what I would have liked. I am watching it closely, no rubbing so have not made a change. It was a bigger job than I thought it would be. New baffling - not sure if that had to be done but mine was pretty beat up and ready for new. |
Was not trying to indicate that anyone was making sub standard parts. The RV4 was not mine, it was one that I had taken on as a side job to help a friend. It was older and the build quality not top notch. I cant say why the cowl and baffle fit were so much different but they were. Even with no baffles the engine just did not want to line up right. Like I said a job like this may be easy and It may not. Ryan |
| All times are GMT -6. The time now is 02:44 PM. |
