VAF Forums
-   RV-14 (https://vansairforce.net/community/forumdisplay.php?f=109)
-   -   Elevator Rub (https://vansairforce.net/community/showthread.php?t=163158)
iamtheari 02-19-2019 06:35 PM
I had rub on the leading edge of my elevators where they met most (maybe all, I can't remember) of the AN470 rivet heads that attach the hinge brackets to the HS rear spar. I was able to massage the leading edges enough to eliminate the rub through the entire range of travel. Just posting this as a data point for posterity.
