This was the first year I drove. It may not be the last. I'm so sorry to read about the experiences a lot of you had. I was sitting on the ground at a nearby airport listening to ATC and talking to the people who landed after running through their fuel.
I think it's great that EAA is taking the issues seriously but unless someone can get the FAA to play ball it seems like little will change. I do think it's unconscionable that anyone actually qualified to fly an aircraft would treat the NOTAM like some optional recommendation. A few years spent on the ground might get their attention. |
This situation is clearly:
1. A significant safety issue that needs addressing, And 2. An issue that deserves careful thought as to the possible causes, true root causes and contributing factors, and solutions. It is great to brainstorm and throw out ideas without jumping to conclusions or blaming groups or individuals before all the facts are in and analyzed. I am sure that with the fine minds available, a good solution will be identified and implemented. At the same time, until that implementation is complete and proven, I will probably not fly in. Some things are beyond my personal risk tolerance. I look forward to an improved future here, and encourage the EAA in its efforts to do a thorough job.. |
Why are people NOT getting violated for doing stuff like that? If people knew they would get nailed they would be less likely to be cowboys. I know it isn't fun for the FAA to do that but if they don't... |
screen off, and keep my head outside where it belongs. SEE & be seen!!! |
Just curious, with all that traffic so close together how do you suppress "TRAFFIC" alerts on your ADS-B Out/In equipment? I would think it would drive you crazy, much less scare the heck out of you.
Chris |
| All times are GMT -6. The time now is 12:15 AM. |
