VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   Filled rivet heads (https://vansairforce.net/community/showthread.php?t=162114)
Dave12 07-09-2018 05:52 PM
Filled rivet heads
Does anyone remember what Geico (Larry Geiger) used to fill the rivet heads on the Rv12 he built?
Mich48041 07-09-2018 05:57 PM
I remember that he used a syringe. I do not remember what was in it.
Mich48041 07-09-2018 06:02 PM
I did a google search for "syringe vansairforce geico" without quotes and found THIS thread. Larry mentioned Superfil.
David Paule 07-09-2018 07:39 PM
I've heard of using 3M's 2216 epoxy from a syringe.
Dave
engineerofsorts 07-10-2018 02:55 AM
I used colored epoxy
I used a rather fine-gauge syringe with the plain old west system resin/hardener I used on the fiberglass. I found it difficult to see how much epoxy was going in the hole, so I used some colorant (comes in a tube from West) to give it some opacity. Since my rivet puller tended to leave a burr on the mandrel hole, I gently demurred the hole before filling with epoxy. If the epoxy is a little too high, it can then be easily sliced off with a blade after curing. (If there is a burr, it makes sliced the excess off a real pain). It sounds, and is, tedious, but I would guesstimate I did the exterior rivets on the entire plane in about eight hours, and I?m quite pleased with the results after painting.
bcondrey 07-10-2018 09:40 AM
I ran into Larry a few weeks ago and that very subject came up. He used a syringe and needle from a farm supply store and injected micro into the rivet heads. Subject came up while he was looking at the local Aviation Nation RV-12 teen build that I?m helping with.
Phantom30 07-10-2018 11:45 AM
I can verify that filling rivets will add .0001 knots to cruise speed 🤓
rv9builder 07-10-2018 09:43 PM
Is appearance the only reason to fill the rivet heads? Is there a practical reason, like keeping water out of the wings and fuselage when it rains or preventing loose mandrels from falling out?
RFSchaller 07-10-2018 10:01 PM
Looks like the answer to the question nobody asked!😜
Definitely more work than I want to do.
Gagarin737 07-11-2018 03:12 AM
The reason for me to fill the rivet heads was to keep the dirt out. I saw an aircraft with unfilled rivets and that particular plane had black strips running from the rivets.
It took about 40 hours to fill/sand all rivets, not that bad.
