VAF Forums
-   COMM (https://vansairforce.net/community/forumdisplay.php?f=38)
-   -   Icom IC-200 pixels going out, easy fix? (https://vansairforce.net/community/showthread.php?t=161703)
wrongway john 06-25-2018 03:30 PM
About 1/4 of my screen has blacked out, barely can read the numbers now. Can I get another screen, and if so, is it an easy fix? If not, know who works on these?
John
fl-mike 06-25-2018 07:32 PM
Try cleaning the screen flex contacts first.
wrongway john 06-26-2018 06:25 AM
Next few days, I'll look at some of the contact points, clean 'em up. Be nice if that is all it is. Thanks, Mike
Michael Henning 06-26-2018 05:45 PM
There is a service center in Syracuse, NY. Fast turnaround, reasonable price and they are factory authorized.
wrongway john 05-04-2020 11:07 AM
^^^Michael, I know this is a bit late, was hoping to fix this myself. There appears to be a few in Syracuse, do you or others have a particular one in mind? It's gotten a bit worse, one-third of screen is blacked out now, I hate to shut down plane again after going through a lot of stuff and getting it all up to par again, but this has gotten to be a bit too much. Great radio, transmits and receives well, but screen is shot. Definitely want one with a fast turn around, or someone here that has previous experience with a radio shop they have had a positive experience with.
Raymo 05-04-2020 11:58 AM
Check continuity on the ribbon cable wires. Replacement ribbon cables are available.
wrongway john 05-04-2020 07:58 PM
^^^Worth a try before I send it off. Thanks.
kkmarshall 05-04-2020 08:08 PM
Does the A200 have a ribbon cable? I didn?t know that.
GalinHdz 05-05-2020 03:47 PM
Might be confusing it with the A210? Dunno!!!
:confused:
wrongway john 05-05-2020 06:50 PM
Took it apart this evening. No ribbon strip on my IC-A200. Was hoping I could just order another lcd, probably could have, but there are about 8 or so wires soldered on board that I would have to heat up first to pull it. Still might do it, that way I can still be flying until part gets here. Then only be down just a few hours instead of I?m guessing 7-10 days for some shop with turn around and all.
Here?s a bit more detail on this radio along with part numbers, as well as some good pics of the inside.
http://www.aeroelectric.com/Installa...00/A200_SM.pdf
