PRC substitute?
I have had a lot of headaches with PPG trying to source PRC to European clients and am wondering if anyone out there has used another two-part polysulfide similar to ProSeal B2 that they were happy with? Any suggestions appreciated.
Eric |
I've used the Chemseal products from Spruce with no problems, other than the usual sticky mess ones. :)
I think the key is simply to buy to the correct specification whoever the manufacturer is. From the PRC document - Meets requirements of specifications AMS-S-8802 formerly MIL-S-8802, We typically use type II, Class B, with the following number giving the working time in hours (usually 2). Just buy to the specification, the Chemseal product meets the same spec. |
Last time I purchased, the 3M AC Tech was the lowest cost in the U.S. |
In the UK Silmid is a major supplier with a good selection of PRC sealants.
I suspect there are other suppliers in Europe as it is commonly used in the aerospace sector. |
PR1440
https://www.silmid.com/sealants/fuel...138-msrr-9144/ Its twice as expensive as the stuff we used for 30 years (I think that was PR1412), but that has fallen foul of the REACH regulations. Pete |
http://www.ppgaerospace.com/Products...k-Sealant.aspx |
That makes sense to just buy according to the spec. Very helpful everyone, thank you!
Eric |
| All times are GMT -6. The time now is 03:01 PM. |
