VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   MANUAL FLAPS FOR 6 7 AND 9 (https://vansairforce.net/community/showthread.php?t=16119)
gasman 03-17-2007 02:46 AM
MANUAL FLAPS FOR 6 & 7
If you are interested in converting to manual flaps,drop a note here. If ther is enough interest, I will draw up a conversion using your existing weldment used for electric flaps and get them to you. Motor dog house is gone between the seats. And all of the reliability problems are gone. BUT you do need BUTT space between the seats. You will always know where your flaps are set. You will never have to turn on the master to lower or retract the flaps...... let me know.
rtry9a 03-17-2007 11:01 AM
Im interested in your manual flap ideas.
Mike Parker
qtrmiledan 03-17-2007 11:19 AM
Manual Flaps
I'm interested!
cjensen 03-17-2007 12:06 PM
I'm interested as well, but I'm already designing my own...I'd like to see or hear your ideas though! :cool:
plaurence 03-17-2007 03:27 PM
Originally Posted by gasman
If you are interested in converting to manual flaps,drop a note here. If ther is enough interest, I will draw up my conversion using your existing weldment used for electric flaps and get them to you. Motor dog house is gone between the seats. And all of the reliability problems are gone. BUT you do need BUTT space between the seats. You will always know where your flaps are set. You will never have to turn on the master to lower or retract the flaps...... let me know.
Count me in.
P Laurence
Sam Buchanan 03-17-2007 04:14 PM
Just as a datapoint, the electric flaps can be wired directly to the battery via a fused lead. That is the way mine are wired and it is very handy to be able to activate the flaps without the master turned on.
Guess that just eliminated one rational for manual flaps....... ;)
ao.frog 03-17-2007 04:48 PM
Another one
Please count me in too.
Regards Alf Olav Frog / Norway
RV-7 Finishing
frankh 03-17-2007 05:11 PM
Yes sir!
lighter, less complexity and less points of failure
Can't beat that with a stick!
Sam Buchanan 03-17-2007 05:50 PM
I understand what you are saying. Unfortunately, manual flaps are somewhat of a hassle to use in an RV. I had manual flaps in my RV-6 for a couple of years, but after converting to electric flaps five years ago, I definitely have no desire to go back to manual.
As the original poster stated, you have to have "butt" space between the pilot and passenger in order to use manual flaps (if either pilot and passenger are near 200lbs there isn't much.....and if both are bubba-sized, there ain't any!). And those pilots who have only used manual flaps in a Cherokee are going to be surprised at the amount of grunt it takes (and how your elbow ends up in the side of your passenger) to pull the final notch of flaps manually in an RV.
But...to each his own. I just can't think of any good reason to convert my plane back to manual (would mean ditching the cupholders between the seats :) ). Besides, if the flap motor fails, there is no reason why a landing should be compromised.
rvwantabe 03-17-2007 07:06 PM
I would be interested in the manual flap option for my 9.
Daryl
