Am I reading the Hartzell install torque table correctly? I think for the four AN4H-4A bolts to the S-603 front spinner bulkhead the torque should be 20-22 ft-lbs but it isn’t explicitly called out like it is for the hub clamping bolts to the spinner plate assembly.
| All times are GMT -6. The time now is 05:06 AM. |
