Tip: Elevator Trim Hinge Pin
This is an idea that many people have used in the past. Unfortunately, I found out about it after I had built my RV-6. I struggled with finding a way to secure the hinge pin on the elevator trim tab until I saw this technique used on some RVs that I looked at up at Air Venture.
As supplied in the kit, the hinge is longer than what's needed. When you trim the hinge to length, be sure to NOT cut the hinge pin. Leave it long and extending past the end of the elevator as shown above. Now bend the hinge pin so that it will lay across the web of the spar. Take a spare piece of hinge and cut out one eye. Drill a hole in it for a #6 screw. Slip it over the hinge pin and locate the position of the screw hole in the web of the spar. Remove everything and attach a #6 nut plate behind the hole. The nut plate will fit on the forward side of the elevator trim spar web where it extends past the edge of the inside elevator rib. When you're done, you'll find that you will be able to get a long bladed screwdriver on the screw even with the trim tab mounted and in-place. |
Done-got it. only need another pin
Well, I got her. All I had to do was chisel out my foam job, and follow the instructions. ( those rivets on the nut plate fought me, didn't want to sit in straight.)
Had to clip a loop off, because the wire/pin wouldn't sit right, Clipped the first one, don't need it anyway; and then I'd wished I'd read line #4 and let it sink in. I'm a loop short on length on the other end after cutting my wire... :o But I got her.... http://www.pbase.com/mark2nite/image/43598455 ![]() |
just did it that way
thank you randy!
Good suggestion.
I like it and have decided to use it on my RV-10 trim tabs. I have already made the bends like Vans calls for. I was waiting to buy a set of safety wire pliers before finally securing the pins. Thanks!
I can't believe I've been on this site for over seven years! BTW, you are welcome.
I saw this or a similar post with similar "solution" a few years ago when I too had to secure the elevator trim hinge wire. I didn't like the proposed new method and stayed with Vans' plans, as I have had for most such "improvements".
Vans method -- at least for the -9 -- is to simply safety-wire the hinge wire to the trim spar. Easy, takes a minute, and most important to me, the only failure mode is of the safety wire; unlikely from fatigue since it's quite malleable obviously. Also, easy to look at in a preflight and see if it's broken. The proposed "improvement" is more complicated, takes considerably longer to install, and has more failure modes: the rivets, the screw, the small clamp. And the failures may not be obvious. The new method offers no improvement but several disadvantages. But it does look better...kinda more engineery. I post this not to bash the OP but to simply put on record for any newbs out there that there is little reason to depart from Vans plans and methods. When I have done so I have come to regret it. |
nose wheel
My point is that the RV-1 is not like the RV-4, the 6 is not like the 7. Things change at times for the better. Just because it was designed by Vans, does not mean it is the best that could be done. Production costs, time, and a million other things enter into a kit. I completely agree about following the plans and it will save you time and money. It could save your life if you make a change that has not been engineered correctly. But, there are errors in my 9 plans and there are many ways posted by others that make the build easier and in many cases, better. I go back to the nose wheel. Even Vans finally made an upgrade there. In my opinion, the nose wheel is still the weakest part of the entire plane and without changing from the plans to add strength, I would not be building a Vans at all. I was out in Sacramento a couple weeks ago near the Exec. airport off Freeport. Boy I don't miss the heat of the Sacramento Valley! I lived in Cameron Park until we moved to Colorado 5 years ago. |
There are many things in the original design that can be improved
Bob Axsom |
| All times are GMT -6. The time now is 07:33 PM. |
