VAF Forums
-   -   RV Bits RV8 Intersection Fairing (https://vansairforce.net/community/showthread.php?t=160465)
RobinHou 05-15-2018 02:44 PM
I brought my intersection fairings from RV Bits. The right side fits reasonably well. The left side does not come together at the rear, and leaves a gap to my wing fairing.
https://photos.app.goo.gl/qy2mM4CM98OqOJ4f1
https://photos.app.goo.gl/3ipUhWrE6hmDha2i1
https://photos.app.goo.gl/pmzKeYcA4FZ4n0XU2
I am looking for suggestion on how to fit the left side better.
Thanks in advance.
smithflys23 05-15-2018 04:26 PM
I just ordered these, so I will be interested to read what suggestions you get.
wilddog 05-15-2018 05:27 PM
How much of a gap do you have at the LG leading edge, where your thumb is in the last picture? Looks like the fairing needs to slide back a little and the upper part is stopping it. Cut it off??
RobinHou 05-15-2018 06:00 PM
There is no gap at the LG leading edge. Maybe I should slice/cut the upper front part so the entire fairing could slide up and back, then I can patch the slit to conform the fuselage/LG leading edge?
Here is a picture of the proposed cut in red line:
https://photos.app.goo.gl/36DR7IjL0PoRb0e43
Steve Barnes 05-15-2018 07:39 PM
Cut and slice
Robin, I am RV Bits main competitor. From the looks of it you can cut the sleeve around the gear leg up a little and it will slide back a little. you may have to trim back a little where it goes around the wing leading edge too.
Steve Barnes
RobinHou 05-16-2018 03:22 PM
Steve Barnes
Hi Steve,
It is very nice of you to help out your competitor's customer; thank you.
When you said "cut the sleeve around the gear leg up a little", do you mean to trim off the top part of my gear leg fairing then push it up a little, so the portion of the gear leg fairing under the intersection fairing is narrower?
Robin
Larco 05-16-2018 04:18 PM
Is it the shadow or is the root fairing a different radius than the fuel tank? It appears from the picture that it might fit the tank radius fine and you just need to rebend the root fairing to match the tank??? Just a thought
