VAF Forums
-   Tip up canopy vs. Sliding canopy (https://vansairforce.net/community/forumdisplay.php?f=55)
-   -   Slider newbie question (https://vansairforce.net/community/showthread.php?t=160450)
Maverick972 05-14-2018 08:04 PM
I have an RV7 slider, I love it and it?s the best option for me.
Sometimes I don?t want the slider to slide all the way back but would like it open a few inches.
How have others made this happen? Thanks
rvsxer 05-15-2018 07:49 AM
For when my RV-6 is parked I have a second slot for the lock that leaves the canopy open 3-4". Maybe you could drill a hole in the track and have a spring-loaded pin that you push down into the hole. It should stay put while the canopy is open due to the canopy wanting to slide open further (at least on a taildragger). To disengage it, push the canopy towards closed a bit, the pin pops out and you can open or close the canopy all the way. Having the "default" pin position as disengaged lessens it interfering with a hasty exit.
Bicyclops 05-15-2018 04:18 PM
It ain't elegant, but I use a spring clamp on the slider side track about 10" aft of the front. The roller butts up to it preventing the slider from moving any further and requiring me to duck my head as it passes. When not in use, I clamp it under the armrest.
Ed Holyoke
Champ 05-15-2018 08:14 PM
Used a couple of Mike Zeller canopy latches on my 8. One at a couple inches open and one at half open. Don?t know if these would also work on a 7 slider.
JonJay 05-15-2018 09:08 PM
Ed Holyoke
Perfect!
Light weight, portable, stow-able, could be used for a variety of purposes. Handy weapon in a nipple pinching contest.
