VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Tip: Rudder Cable Exit Fairings (https://vansairforce.net/community/showthread.php?t=1604)
f1rocket 05-18-2005 12:12 PM
Some folks will look at this as a lot of extra work for nothing. I don't disagree. But there are some builders that just can't stand to see the plastic tubing for the rudder cables sticking out into the wind. I just happen to be one of those builders. Here's how I handled it.
I have seen them just riveted to the outside of the fuselage and also just riveted flush. I thought about this but I couldn't find a way to remove the rudder cables after assembly. The swaged end of the cable will not fit through the opening in the fairing. So I will attach mine with some #4 screws. I don't foresee a reason to ever remove the cables, but it would be just my luck that I would someday.
I ordered a package of cable fairings from Avery. You get three of them in a package. The first step is to trim them to the desired size. I left an even area all the way around, just enough for the mounting screws. Be sure to mark a left and a right one when your done.
Next I cut holes in the side of my fuselage using the fairing as a guide. That's why it is important to mark both a left and a right fairing so the holes will match each part closely. I used some scrap to fabricate a reinforcing ring. In the middle of the ring I cut a slot for the plastic cable tubing. The slot ends just a little short of the end of the fairing so that the plastic tubing will be squeezed by the fairing when it is screwed in place.
After a bunch of drilling and riveting, I screwed the fairing to the reinforcing ring. I then positioned the ring in the skin opening so that I could center the fairing in the opening evenly. I then drilled the attach holes through the skin and ring. After cleaning and dimpling, I riveted the ring in place.
On the inside, all that was left was to make an attachment for the -6 hose clamp to secure the end of the plastic tubing. I made a couple of L brackets from scrap and riveted them to the longeron. I used a nut and bolt to hold the clamp to the bracket.
When I was all done, this is what it looked like. Now I like that much better than just a slot.
fehdxl 05-12-2011 08:35 PM
Randy, Are you still doing it this way... 8-1/2 years later? Or have you come up with a better way? Thanks! -Jim
mike647m 05-12-2011 08:45 PM
I just used proseal. They look great!
fehdxl 05-12-2011 08:55 PM
Mike, Just stuck to the outside? Or did you make the hole in the skin bigger and stick it to the inside? Pictures? ...maybe I need to start a new thread... Thx. -Jim
Rick6a 05-13-2011 05:34 AM
Stick it
I just used proseal........
Attached with proseal only, the rudder cable fairings on my -8 are not going anywhere. To assure a proper bond, adequate surface prep recommended. Using no rivets or screws for traditional attachment, the simple technique eliminates the chance of moisture potentially gaining a toehold between the fairing and the skin.
mike647m 05-13-2011 09:56 PM
Yes, like Rick says
