VAF Forums
-   -   Do you use the Bluetooth function of your headset? If so how? (https://vansairforce.net/community/showthread.php?t=160289)
lndwarrior 05-09-2018 07:21 PM
I'm trading in an old set of Zulu 1 for the new Zulu 3 headset. I never used the function of the Bluetooth in the old ones but I'm wondering if there is some benefit in starting to use it in the new ones?
Just wondering if others are using the Bluetooth function and how they are using it?
TIA
Gary
rvbuilder2002 05-09-2018 07:25 PM
We love our Zulu II's but we never use the bluetooth because we power them with AA batteries and my experience is that using bluetooth runs down the batteries quite a bit faster.
emuyshondt 05-09-2018 07:25 PM
I connect my iPhone to make phone calls, such as to clearance delivery (I?m at a non-towered airport) or calling home. I can also play music from my music library. I get audio warnings from ForeFlight or anything else running on my iPhone or my iPad.
Carl Froehlich 05-09-2018 07:27 PM
TIA
Gary
Yep. Routinely get my IFR clearance going out of VA42 using my phone to the Lightspeed headset via Bluetooth.
Carl
catmandu 05-09-2018 07:57 PM
Just today, connected my Zulu 2 to my iPhone prior to start, called Potomac for my SFRA code, hung up and started some tunes from a cache on my RadioParadise App for the short 15 minute flight home. I LOVE that bluetooth functionality.
airguy 05-09-2018 08:49 PM
I use my A20's on panel power, so the Bluetooth power budget is a non-issue. Phone calls and texting, and music inflight when not in a high workload environment.
Ironflight 05-09-2018 09:53 PM
Never - becasue all of our audio panels have Bluetooth built in. But I would hate to be without the BT functions, so if your audio panel doesn’t have it, I’d definitely want it!
BigJohn 05-10-2018 05:17 AM
I use the BT feature of my A20 frequently to link to my iPhone. Once you make the initial pairing it is just a matter of flipping the switch on the A20 controller and it connects instantly. The quality of sound is excellent and very readable over the engine noise.
Auburntsts 05-10-2018 05:23 AM
Count me as another who routinely uses BT to connect my phone to my A20 in order to get IFR clearances on the ground.
I have the older A20 so it doesn't do BT music, but if it did I'd use it for that too. I like to listen to music enroute and find it doesn't interfere with IFR communications at all. Right now I use a patch cord for music. We don't use the audio panel for that as everyone likes to listen to their own playlist to everyone uses patch cord to listen to their own individual devices. I looked up at updating our A20s to get BT music but in the end decided not to foot the bill.
rleffler 05-10-2018 05:29 AM
No, I have Bluetooth in my audio panel. Although, I have thought about upgrading just my headset to Bluetooth. While PSE states that my 8000BT can support two sources, I've only been able to get it to work with one.
I would like to support both my iPhone and audio source (iPad) at same time.
