Automatic Pitch Trim and VPX
Hello
Time to upgrade my TruTrack AP equiped RV-7A with an Automatic Pitch Trim module. One big question ... does it work in with a VPX? Because the unit gets joined between the VPX and trim servo, the VPX will see some signal/triggers on the output ... Schematics here: https://cdn.shopify.com/s/files/1/21...51448760409847 So far I did not got any answer from Vertical Power support ... Hope Chad is reading this. Thanks for any information ... maybe you are running it allready on your plane. |
Wire it like it states in the Vertical Power install manual (5.19c) and the Trutrak install manual you'll be fine. The VP manual only shows the connections unique to it. |
Hello Bob
Thank you! Ok, my fault not looking into the actual VP manual ... just was reading the TruTrack manual and my "old" VP manual ... BR |
The TruTrak module disconnects the wires coming from the VPX when the auto pilot engages and runs he trim by itself. The VPX doesn?t know the difference.
Yes, the autotrim module works great with a VP-X. You'll have to dial in the setting using the adjustment knob-on the autotrim box, so be sure you have some access to it while flying.
Adjustment only once?
Hello Trevor
Do I have to adjust this only once after installation ... Or from time to time ... Or during every flight? |
Good Question
Thanks to all that responded ... waiting for the auto trim to arrive!
| All times are GMT -6. The time now is 12:07 PM. |
