Fuel Pressure loss on Loop upline
Airplane - F1 Rocket, IO-540 D4A5, recent install of Red Cube between fuel servo and spider. Engine driven fuel pump has ~350 hours.
Pulling 3 g's at the start of a loop I am experiencing a fuel pressure loss from the normal 20+ psi to ~8 psi (engine loses power) after which my boost pump automatically kicks in (power picks back up) and brings the pressure back to normal. I can fly around all day, pulling 2 g's in 60* banks, and no issues, fuel pressure stays 20+ psi. Anybody experience the same? Am I correct to assume a new engine driven fuel pump is in my near future? |
Consider the changes you made, and start there.
First, it worked fine prior to relocating the red cube, yes? I assume you're measuring pressure at the engine pump outlet. If so, nothing you plumbed between the throttle body and the divider would make a difference. I further assume the red cube was previously firewall mounted between the bulkhead fitting and the engine pump. If so, you changed a hose and/or hard line as part of the relocation. Thus three possibilities; the new lines pick up more heat than the previous install, or one of the fittings has a small air leak, or you installed a right angle fitting and (combined with heat) it is forming vapor bubbles in the flow. |
Mark----did you have previous flights in this configuration and 3g's with no issues?
Tom |
Will check the fittings for a leak, although why "G" forces would exacerbate a leak I am not sure, but possible. No right angle fittings were introduced. EDIT: This is not fuel flow related, I have confirmed via flight testing. |
Hey, it's the long distance diagnosis game, with the usual lack of information. Maybe right, maybe not, but I usually have a logical reason for a suggestion. |
location, location, location
Where did you mount the aerolab relative to the exhaust tips?
Or how many inches aft of the firewall? I am guessing it is somewhere in the center tunnel belly skin. I am also guessing on take off, below 500ft, you have your boost pump on? The exhaust pulse is a vibrational shake and bake to anything on the floor skin near the center tunnel. Might just be bubbles manifesting from the increased flow demand when you pull the nose vertical. A 2 G level turn will need less power and fuel flow than a 3 or 3.5 G pull up. |
| All times are GMT -6. The time now is 12:39 PM. |
