VAF Forums
-   -   Milling work needed...small job (https://vansairforce.net/community/showthread.php?t=159810)
istrumit 04-22-2018 06:03 PM
Hi everyone,
I need two small disks made from aluminum.
OD: 1-3/4"
Thickness: 1/16"
These will be attached to the front gear fairing (RV-10) where the tow bar attaches so that the tow bar won't bash/scratch the fiberglass.
I had these before but they popped off in the cold...so I need couple more (and some better way to attach, lol).
If anyone out there has an idea where I could get these or if anyone has the ability to make them, I would really appreciate it.
Scott
Michael Henning 04-22-2018 06:21 PM
Use 3M 5200 as the adhesive next time... they will never ever ever come off. You can buy a small toothpaste tube size from Lowe?s for about $5.
Sam Buchanan 04-22-2018 06:31 PM
McMaster-Carr has aluminum washers very close to this size.
https://www.mcmaster.com/#93286A058
scsmith 04-22-2018 07:31 PM
You could easily make your own using two sizes of hole saws. Cut the big hole first, then cut the small hole in the disc. Holding onto it is a little tricky - maybe make some plywood plates to sandwich the disc.
Plummit 04-23-2018 12:29 AM
I would cut the small hole first, then cut out the piece (big hole) while you have something to hold on to. Use a piece of wood under the aluminum to center the drill pilot.
-Marc
9GT 04-23-2018 06:45 AM
Double sided carpet tapes works great for this kind of stuff. Use a piece of plywood or flat board as the backer.
N329JR 04-23-2018 06:50 AM
I would be happy to machine these Al parts for you. If you would like to PM or email me your contact and shipping information.
Ian
scard 04-23-2018 10:16 AM
I'll see your carpet tape, and raise you some masking tape and superglue :). (thinner firmer stackup)
RV7A Flyer 04-23-2018 10:18 AM
How well does a flat washer that size match the very slight curvature of the nosegear fairing?
I'm looking for just this solution, but want something that doesn't stand out as being a kludge.
Sam Buchanan 04-23-2018 10:43 AM
Bend the washer???
