VAF Forums
-   RV Building Tips/Techniques (https://vansairforce.net/community/forumdisplay.php?f=74)
-   -   Panel - Paint or Powder Coat (https://vansairforce.net/community/showthread.php?t=159712)
jeffw@sc47 04-19-2018 07:20 AM
Has anyone painted their panel instead of powder coated - and found a paint that they would recommend for durability, or have any feedback about painting vs. powder coating? Looking at painting only as a small savings in cost, not entirely sure it is worth it to powder coat.
TShort 04-19-2018 07:24 AM
SteinAir painted and then laser etched / filled my panel for me ... no long term testing yet, but the paint is surprisingly durable. I've installed nuts on switches, etc and have not had any issue with the paint whatsoever. It looks great.
Mel 04-19-2018 07:26 AM
If you are like many of us, your panel will be modified over the years because of adding and/or changing avionics or instruments. Painting is much easier to "touch up" than powder coat.
$.02 to your favorite charity please.
larrynew 04-19-2018 07:45 AM
Despite what I thought was the exact panel I would have for a long time, I've changed it 3 times in 3 years. Very happy with the paint, though. Tough, just the right amount of semi-gloss. Sherwin Williams JetFlex Interior Aircraft Finish L09026, Robin Blue, BAC 510. Will use the same exact if I build again.
dweyant 04-19-2018 08:10 AM
Paint (did it myself) but Stein cut the panel and did the layout.
Three years and 350+ hours and it still looks new. No major modifications, but I've drilled a couple new holes (oil cooler) and no issues.
-Dan
Aluminum 04-19-2018 08:31 AM
Another vote for paint over powder coat here.
Or, you can do what I did and simply use black-anodized .063 Al sheet for panel and engrave or laser-etch through the anodized layer. The anodization is tough but will scratch with enough encouragement and is not as easy to touch up as paint. Mine looks great after five years though, I'd do it again.
bcondrey 04-19-2018 09:31 AM
Yet another vote for paint. I've used PPG Concept over epoxy primer for multiple panels and they've been amazingly durable.
scard 04-19-2018 09:39 AM
Rustoleum rattle can gray. 11yrs 2000hrs Still looks surprisingly good.
Kyle Boatright 04-19-2018 09:40 AM
Rattle can paint has held up well on the panel of my -6 for 17 years. So, if you like the look of paint, that's an easy solution.
uk_figs 04-19-2018 09:46 AM
+1 for rustoleam rattle can
Used the gray like Scott on panel, roll bar etc, 10 years later and it still looks good. Easy to spray (used the primer first), flows well, sets up quickly, and seems to handle a wide range of application temperatures. I used the Brother TZ tape labeling machine for the labels and they look OK as well.
Figs
