VAF Forums
-   -   Compressed Air Hose Size (https://vansairforce.net/community/showthread.php?t=159637)
bayoubengal 04-16-2018 05:59 PM
Hooking up my compressor. Any pros/cons for 1/4 or 3/8? line?
scard 04-16-2018 06:07 PM
For building an RV? Unless you are going further than 500' with 1/4" hose, NO. It doesn't matter.
wirejock 04-16-2018 06:14 PM
Building or painting
For building (riveting, drilling, etc) I use a 1/4 line long enough to cover my work area.
For painting (HVLP) I use a 3/8" line.
Maybe it doesn't matter. I've sprayed with the 1/4" with no problems.
az_gila 04-16-2018 07:22 PM
Use this handy little chart -
A 5 cfm die grinder at 100 ft has a pressure difference of about 10 psi for a 100 ft of 1/4 vs 3/8. probably would have no effect.
However, if you have a big honking compressor and have tools that use a lot of CFM, then the bigger hose size would be better. :)
I sometimes need almost 100 ft lines to get air out to the ramp in front of my hangar.
SMO 04-16-2018 07:59 PM
My die grinder and my orbital sander run noticeably stronger with the 3/8 line. I use 1/4" line for my 1/4" drill, rivet squeezer, cleco remover, and pull riveter.
coffeeguy 04-16-2018 08:19 PM
Looks like I overbuilt. Story of my life. :) Put in 3/4" Rapidair line to my basement and garage and have 3/8" hoses. I have added the 1/4" flexible Cleaveland hose for ease of use the last few feet. And when I cook I always have leftovers...
David Paule 04-16-2018 09:16 PM
Hoses have differing flexibilities. I prefer the more flexible ones - to me, with my limited hose lengths (typically 25' or 50') that's more important than size. However, I haven't painted with these yet.
Dave
gasman 04-16-2018 10:43 PM
When plumbing for air, consider each 90 degree elbow to have the same loss as 20 feet of same size pipe...... you can't overbuild.
