VAF Forums
-   RV-7/7A (https://vansairforce.net/community/forumdisplay.php?f=7)
-   -   Structural effects of Rosen Sunvisor? (https://vansairforce.net/community/showthread.php?t=159586)
roofus4 04-15-2018 08:10 AM
At Sun-n-Fun, I picked up a pair of Rosen Sunvisors, but made sure they are returnable, because I?m concerned about the structural affects it may have on the roll bar. They are only for the -6,-7, and -9 sliders, and they require drilling two holes in the rollover bar. The holes would be large enough to accommodate an 8/32 riv-nut. Has anyone installed these in their plane, or does anyone have any thoughts on the effects this may have on the rollover bar?
If you have installed them, how do you like them?
https://generalaviationnews.com/2014...nopy-for-vans/
Thanks Guys
Larco 04-15-2018 03:08 PM
Thanks Guys
Probably no more affect than the handle install?
pilotkms 04-15-2018 09:36 PM
Check the instructions. I installed mine a year ago and don’t recall rivnuts. I think I threaded the roll bar tapping a 1/8” hole. And I’m no engineer but it’s steel and strong.
roofus4 04-15-2018 11:12 PM
Originally Posted by pilotkms (Post 1253360)
Check the instructions. I installed mine a year ago and don?t recall rivnuts. I think I threaded the roll bar tapping a 1/8? hole. And I?m no engineer but it?s steel and strong.
That?s interesting. I?m just going by what the guys at S-n-F told me. I haven?t had a chance to dive into the instructions yet. Thanks for the guidance.
Btw, how do you like them? Do they get in the way when not in use?
uk_figs 04-16-2018 06:41 AM
YMMV
I installed them and ended up removing them as they never seemed to be where the sun was. After a few years they started to droop occasionally also.
Would be easier to just put a strip of the sunshade film you can buy across the top like they have in cars. I have this on the slider portion either side of the center rail and it works well.
Figs
Jpm757 04-16-2018 07:49 AM
I agree that you are better off drilling and tapping, rather than installing aluminum rivnuts. I have never had any luck using rivnuts, they require a large hole, and invariably strip out and or loosen after time. The rivnuts will not hold up to the constant movement of the visor.
roofus4 04-16-2018 08:17 AM
Awesome info guys! Thanks! I got them on a whim without doing much research because of the show price at Sun-n-Fun and they told me I could return them if they are unused. Sounds like my $400 would be better spent elsewhere...
