I'm not a EE, and I don't pretend to understand antenna theory - but I am of the understanding that separation of antennae becomes critical only when the operating frequencies are fairly close together. If I'm wrong about that I'm sure a few others will chime in to correct me - they always do - it's actually one of the traits I value most about this forum. My separation distance between the transponder and the UAT antenna was a happy accident - during my early build I knew I would be nose-heavy due to other design constraints, so I was moving any equipment aft that could be moved. That included the transponder and its antenna - and they ended up residing just forward of the static port locations. The UAT came onto the market later and I was able to put that antenna under the seat pans between the comm antennae without any difficulties. |
I have an Echo UAT to be installed in the next month (by moi) and I'm wrestling with the antenna location. Uavionics calls for 3' mininum separation from either xponder or comm antennas, which forces my ADS-B antenna back in the tailcone; and that, in turn, puts it further from the ADS-B box(es) than the 8' maximum they state for RG400. The lower loss coax options (primarily RG304 and RG393) are hard to find and terribly pricey. ($10/ft!) If I could get away with 2' separation, it simplifies my installation a bunch. :)
Carl |
No issue running the power and rs-232 lines all the way back there. Unit is very small and easy to mount about anywhere without structural support. Larry |
In both cases the boxes are aft of the baggage bulkhead. |
Yes.... putting the Echo UAT behind the baggage bulkhead is an obvious alternative. I have (had, perhaps?) a desire to keep all my avionics up front, for ease of servicing and troubleshooting. Additionally, I have the GRT SafeFly which requires a GPS puck-GPSantenna connection also. That is most easily done on the glareshield. As always, it's time vs money for the insallation/retrofit. I may just pay the $10/ft for RG393. :)
Bent whip vs other antenna distances
When measuring out the separation from Bent whip antennas, do you use the tip of the bent whip or the base of the bent whip?
Theres no guidance on this that I've found, so I have to assume that everyone is using the base, even tho I think the correct answer is the tip.......or maybe the separation numbers already include a half foot for the assumed bent whip tip......?????? |
I believe you should have over 3' from UAT to transponder. I have the comms under the rear seats and put the UAT and transponder antennas under the front seats at the outer edges, just fwd of the gear legs. I have 3.5' between the two and over 3' from the Coms. If I have problems, I'll move the ADSb to the rear area.
Larry |
The question is from where is the actual distance measured..........Bnc to Bnc connector?.......or some other point for measurement? |
| All times are GMT -6. The time now is 03:03 PM. |
