I did a condition inspection on a 6-A that had the flywheel mounted one hole off (with constant speed). Rather than pull it off and mount it right, whoever did it just used a felt tip pen to place new timing marks.....ya sure do find a lot of strange things.:rolleyes:
The hole in the crank flange is 0.031 larger diameter. The non-index bushing would not be a friction fit. See link in post #8. However, with a big enough hammer I'm sure someone could make the flywheel fit in any orientation. :D |
Larry |
| All times are GMT -6. The time now is 01:45 AM. |
