Close riveting on 9 aileron
I'm having trouble with this last rivet on the ailerons. I've read that some use a pull or flush rivet here.
[IMG]https://i.imgur.com/O35qLLe.jpg?1[/IMG] What P/N pull rivet would I use? and can it be used with the dimpled skin? Andy C. |
Factory says
I got permision from Eric at the factory to use MK319s there.
Will an MK319 work if the skin is dimpled?
yes
#34 or #33 bit or reamer will work for MK-319BS.
I'm building the flaps now also, that do use the MK319 pull rivets on the bottom skins, and I assumed that you do not dimple those installations?
The MK319 rivet is a counter sink rivet, therefore it must go into a dimpled/ countersink hole
With further looking, I see that! Needs a dimple.
Good to go slow and check things out. Can these blind rivets also be used for the close locations on the flap top skins? |
Close riveting
I did a little creative grinding on old ax head to use as a bucking bar with quite good results on my 8 .
| All times are GMT -6. The time now is 03:37 PM. |
