SB 18-03-06 Posted
RV-12 (Powered with Rotax 912ULS) ALSO SEE Revisions and Changes
Replace the throttle return springs. http://www.vansaircraft.com/pdf/serv...sb18-03-06.pdf http://www.vansaircraft.com/public/service-rv12.htm#rev v/r,dr |
I have just received from McFarlane Aviation the new sided springs that are colored Red for L/H spring Mc Farlane p/n 6822 and Blue for R/H McFarlane p/n 7235.
Can anyone confirm these are the same spring now required in SB 18-03-06, and are identical to and interchangeable with Van?s Part No SPRING-00002-L/R-1? |
They are NOT the same spring.
The new spring mounts on the throttle shaft and I expect the new design will all but eliminate the occasional breakages we've all experienced. Thank you Van's engineering for your continuing efforts to improve the RV-12! |
Shame the original spring is on 50-01 just to confuse.....:rolleyes:
After a quick look at this, it appears that these old pull type throttle springs are being replaced by torsion springs, rather than with the old pull type spring.
Is that correct? If so, this is a fantastic mod!! My guess is that a torsion spring will probably end throttle spring breakage. Tom |
Jeez, just started my annual last weekend, and I'm actually falling behind in SB compliance already!:eek:
Actually, I'm very pleased Van's is upgrading these springs. I had two replacement springs fail in 2016 (reported to Van's) so it appears its been an ongoing problem. Glad to see they continue to support us. |
The new spring was conceived at Van's, and then designed under corroboration with the engineering dept of a local spring manufacturer so this should be the end to throttle spring breakage.
As the fleet begins using the new spring, be sure to notify Van's using one of the standard procedures detailed in the maintenance manual, if you have any type of service difficulty with them. |
Spring force
How does the new spring force compare to the previous spring?
The original spring force was not sufficient to keep the carbs synced during throttle advance. I did replace the throttle/cables and they start out good, but then start sticking. I finally resorted to the original Rotax springs. They worked well except reduce the effectiveness of the throttle vernier feature. Hope the new springs exert more force than the original. |
The safety scenario goes like this… you’re flying along and one of the cables breaks or becomes disconnected. The offending carb now advances to full throttle with its safety spring and the carb that is still controllable follows the pilot’s input. So one carb is full throttle and the other is nearly so. You will probably notice some vibration and even worse vibration if you throttle back because one carb will stay at full power while the other carb is at reduced power. This is the indication that one throttle cable has malfunctioned and now you need to plan your decent to landing. No real problem – just advance throttle to full so both carbs are equal power and find nearest airport. Begin a slow decent to not over-speed the engine too much and then cut power to both ignitions to shut the engine off when you have the runway made. Best to pick long runway… Because the Rotax 912 is really two separate power sources married to one crankshaft its important to never have a huge imbalance of power between the halves. This is why power is advanced to full instead of idle. Idle would require an immediate decent with the working carb brought back to reduced power to prevent the engine from shaking itself free of the airframe. Full power on both halves of the engine allow the pilot to plan and execute a safe landing. So what makes the Rotax 912 operate as two separate power sources? The fact that it has two separate carburetors – one for each side of the engine. Lycoming and Continental engines have a single carburetor and so the entire engine follows good or bad. Sorry for long post… |
Add to POH
Perhaps a worthy candidate for a POH emergency procedure?
The springs perform two functions.
The first, and probably most rare, is to advance one throttle to full power if the cable breaks. The second, and day to day, is to take the slack out of the cables so that both carburetors perform in unison. There is friction in the two cables. If you have a 100-200 hours or so and are using the lightweight springs, advanceing the throttle using the vernier control, you may see that one throttle arm sticks and releases. You can see the effect when using a Carbmate or Tecmate. You can feel it when flying. Replace the lightweight springs with the midweight or Rotax spring, the problem goes away. After some wear in the throttle cable, the midweight springs do not overcome the friction. The rotax springs keep working. I replaced the throttle cable and could go back to the lightweight springs for a while. I then had to go to midweight springs followed by Rotax springs. Thus, back to my question several posts back, where to the new springs fit in the mix? Try to balance the carbs without the springs. My experience is that the results will be erratic. |
The springs were designed to closely mimic the springs that have been supplied with the throttle control by McFarlane (hopefully minus the vibration induced fatigue failure).
The RV-12 fleet is pretty good size at this point and other than a higher failure rate of the springs than should be expected, they have generally given good performance. The cables on the RV-12 throttle control are not much different than those used on motorcycles or bicycles, which have to be maintained to some degree. If they are noted to be developing some friction that wasn't previously present, they can be lubricated with spray lube, and that usually restores them to the way the were previously. |
Beware of assuming throttle cable resistance is just a lube problem. One annual I listed a hard to move throttle as a squawk. Turned out that the cable strands had broke and balled up inside the cable sheath. I only had one or two unbroken strands operating the throttle.
No, a Cherokee. I mentioned it only because it was a life lesson in not jumping to conclusions.
Broken Throttle springs.
Just a question out of interest.
To the people operating 3 blade propellers on their RV12 aircraft, has anyone suffered a throttle spring failure? |
Typo ?
Is there a typo in the SB? The title is SB 18-03-06, but step 4 specifies a logbook entry indicating compliance with SB 17-12-07.
SB throttle springs
What does everyone think about the new style throttle spring?
Torsion Throttle Springs
I've had mine in for almost a year and about 90 hours now. They are fantastic. So glad to have them. They took an RV-12 trouble spot and totally eliminated it as far as I can tell. Thanks to the Van's engineering staff...........Tom
N=2
For those that have installed the new SPRING 00002-1 springs what was the torque kn the bolt? Have perused the Rotax maintenance manuals and cannot find the torque.
TIA |
Found it ..... 44 in. lbs.
| All times are GMT -6. The time now is 11:04 AM. |
