MS-4SPA atomizer??
I'm looking to do the modification to my MS-4SPA 10-5009 and change the nozzle to the atomizer and make it a 10-5009N. From research I've found (mostly on this site), it will alleviate my "Grumman Stumble" problem that I'm glad to hear isn't just my airplane.
I'm looking for info specifically on this modification and/or shops that will do this. Other than starting to cold call local engine shops, I thought I'd start here. Is there a parts kit available from somewhere that I can do this myself? If not, is there a particular shop that is known for working on these carbs? |
Martin inductions
Here's one option:
http://www.martininduction.com Call Gene and tell him what your issue is and what you'd like to do. He is very knowledgeable especially about amateur built aircraft inductions. He is a great guy. Hope this helps, Joe |
Try aerosport power they may give you a list of parts. There are a couple gaskets and lock washers with tabs that need replacing once you pull the carb apart. One of the gaskets is a tiny gasket on the end of the nozzle, when you remove the old nozzle you might not even notice its on there but make sure to install new one on new nozzle. It?s relatively easy to do but pay attention taking apart and reassembling so the internal parts and floats are seated correctly going back together. Perhaps a one hour job but very unforgiving to human error.
Do it yourself
You can easily do this yourself. You don't even have to remove the carburetor from the aircraft - just undo the bottom half. Then switch out the old nozzle for the new one. Here's the kit: http://store.cubcrafters.com/Marvel-...22_p_1470.html
That's exactly what I was looking for! Thank you all for the input. Now I just need to call CubCrafters and see when it will be back in stock...
So has anyone done the -4SPA 10-5009 conversion to -5009"N" on and O-320? That's all I'm looking to do.
Marvel
You can go to the source like I did. I installed it to help fuel distribution, the jury is still out on whether it helped or not.
http://msacarbs.com/666-862-f-60261.html |
The "pepperbox" atomizer nozzle doesn't help all that much in a new ECI Titan O-340 on my RV9A. Mixture distribution is still abysmal.
Don, The link you provided takes me to a conversion kit Part # 666-862-F. I did send an email and heard back from MS Carbs and I was given the Lycoming Service Instruction 1305C which calls for conversion kit Part # 666-813-F.
Is there a reason you used the -862 over the -813? Is there a difference? Any MS Carb guru's out there? Mine is currently MS-4SPA 10-5009 mounted on a O-320-E3D (experimental now with higher compression pistons to 160HP). |
| All times are GMT -6. The time now is 03:14 PM. |
