RV4 wing production run
Great to hear the oldies but goodies are seeing a revival in kit production.
Lots more work but in the end well worth it Cheers, Hans |
Back to the future...
Greg,
The Three, Four and Six truly are timeless airframes, I'm not surprised at the news. I bought my RV4 tail kit in 1988, the RV4 wings and tail currently on my RVX were cut in North Plains in 1979. Now the real question: With all of their metal cutting now on the CNC that cuts the new pre-drilled, fit-designed skins for the newer models, will they update it on the new 3,4 and 6 parts? :) A pre-punched 3-4-6 would be truly, back to the future... V/R Smokey |
I'm glad that I ordered and received all the parts I need to finish my RV-4. (Mel, it won't be long before you get a call to come and make it an airplane)
CNC is AOK...
Mel,
Maybe using the old machines and tooling will be more expensive and it will be financially advantageous to use the CNC. Man, that's alot of holes not to have to drill... Maybe.... V/R Smokey PS: What does a modern RV3 style sportplane with pre-punched skins, RV8 landing gear, folding wings and more engine options look like? Van could learn from this one :) https://flywithspa.com/product/panther-full-kit-2/ |
I think that updating the kit would increase sales, at least with the 4. I think there are a lot of builders building 8's that would be building 4's if they kits were at the same level. I'm biased, but I think the 4 is a lot better looking airplane than the 8. bob burns RV-4 N82RB |
I have built two Harmon?s. you could order the skins non prepunched and order the wing spars unriveted. Most would opt for larger wing tanks anyways.
Yes there are a lot of holes to drill but making a wing rib drilling jig eliminates a lot of measuring. The jig is just a strip of metal the same length of the ribs. Clecoe it top and bottom thing drill away. Two are required, one for the top and bottom of the ribs. Every plane I have built has taken about the same number of hours. The time saved on improved metal parts has been replaced with the extra time that all the new electronic devices and the associated wiring takes. |
| All times are GMT -6. The time now is 01:07 PM. |
