VAF Forums
-   -   Aluminum rivets on stainless firewall (https://vansairforce.net/community/showthread.php?t=158051)
RandyAB 02-22-2018 02:52 PM
I notice a lot of AN rivets used on the firewall. Any concern for galvanic corrosion with doing this?
airguy 02-22-2018 03:27 PM
Apparently not much more than concern for them melting out in a fire.
jibby212 02-22-2018 03:28 PM
I am always concerned with dissimilar metal corrosion but I live on the Florida coast and see its devastating effects all the time, I used Tef Gel on these rivets. Corrosion Scares me as you can see.
tgmillso 02-22-2018 07:27 PM
I wet set mine with 3m fire barrier 2000+, but at the end of the day, there a plenty of RV's built to spec with the stock riveting process. I just went that additional step because of corrosion I have seen on firewalls of other aircraft.
Tom.
wkevinm 02-28-2018 10:17 AM
Your post peaked my interest so I searched the internet on the topic. Found this site with a good description of the mechanism.
http://www.ssina.com/corrosion/galvanic.html
