VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   Installing SB 18-02-02 (https://vansairforce.net/community/showthread.php?t=157967)
Jim T 02-26-2018 05:52 PM
Originally Posted by Hal-san (Post 1242396)
Received my kit today. There are no barrel clips in my kit.
If you haven't already......look closely in all the rivet bags. Mine were in there along with a couple of cotter keys.
Jim
Hal-san 02-26-2018 06:09 PM
No, they are not in my kit and they are not on the inventory sheet. My kit was shipped on the 20th so they not have been including them at that time. I have several spares that I ordered during my build so it is not a problem.
Hal
RFSchaller 02-26-2018 09:06 PM
I?m just starting the mod. A couple of things I noted:
1. I only loosened one control cable turnbuckle which I hope will allow me to reconnect with only having to wrestle in one set of turnbuckle clips.
2. When the paint shop painted my plane the heavy coat on the bolt and nut heads makes them not accept sockets or open end wrenches of the correct size, and the coat on the spar interferes with the doubler plate fit, so I will be investing in some paint stripper before I can disassemble and install the plates.
AirHound 02-27-2018 11:42 AM
Hey Rich, why not disconnect at the HS horns and tie them together to keep them from slipping into the fuselage rather than messing with the clips? I?m in the reading/planning/? Phase.
Phantom30 02-27-2018 04:12 PM
They are pretty near impossible to remove @ HS horns if you do not loosen at least one turn-buckle. This would likewise be a problem during reassembly.
joedallas 02-27-2018 04:27 PM
Longer Cable Adjustment
Yes on the reinstall.
I believe the cable adjustment needs to be a little longer due to the spacer behind the hinge moves the Stabilator back a little ?
Your RV12 is now a little longer.
Unless Vans moved the bolt for the hinge back to adjust for the spacer.
Joe Dallas
rvbuilder2002 02-27-2018 05:25 PM
Joe Dallas
They did move it!
AirHound 02-28-2018 05:38 AM
Approx How many turns/how much movement is needed, would you guess?
Bob Y 02-28-2018 05:45 AM
SB 18-02-02 & Paint vs. Vinyl Wrap
I am barely into my empennage kit, so painting is way off on the project list, but this SB caused me to bring-up a discussion with my friend, who?s much further along on his RV-12. This SB brought to my mind the subject of vinyl wrapping vs. paint? Love the claimed benefits of vinyl ? lower cost, shorter down time, less weight. Regarding this SB and Mr. Schaller?s comment concerning paint over the bolt heads making removal difficult, seems this would be another plus for vinyl. However? how does one detect a surface crack and stop drill it before it becomes a real issue with vinyl? And how would one remove a skin with vinyl? This seems to be a key negative I?ve not seen addressed. Anyone have experience here that can help to alleviate this perceived negative of vinyl wrapping?
bob1393 02-28-2018 04:03 PM
installing SB 18-02-02
I received the SB kit today. There were no barrel clips in any of the bags and they are not listed on the parts sheet.
Also - the two K-1000 nut plates were missing as well as the 2 cotter pins.
Jim T 02-28-2018 05:40 PM
Just for reference. I got my kit about a week ago and my clips, cotter keys and nut plates were in the bag with the LP4-3 rivets. I didn't get a parts sheet.
Jim
AirHound 02-28-2018 06:17 PM
HS stab removal process
I?m not the builder. Just thinking through the steps and early comments. Some posts indicate different kit contents, one or no clips, etc, and a couple pioneers indicate different HS removal process steps from sb steps ie; removal of HS horn cables rather than loosening cable adjusters. Perhaps the clips are not necessary and not intended if strict sb steps are followed, therefore the inconsistent amount of clips supplied - as in not really needed. Question I don?t want to hassle with the turnbuckles if the HS horn cable disconnection step in the sb is practical. Specifically, what makes one chose one way to deal with the cables or the other. I?m waiting on parts just trying to understand others comments and make best choices. Thanks! Doug in IL
Originally Posted by rvbuilder2002 (Post 1242687)
They did move it!
MrSparkle 02-28-2018 06:46 PM
Are these cracks or scratches?
I've been unable to get guidance as to whether what is shown in the following five images are cracks or scratches.
Whatever they are, they are tiny and as you can see they are super close to the rivet's manufactured head. If they are cracks, do I drill a hole so close to the rivet; and when the drill bit works through the spar web won't it then bite into the rivet's shop head, or the nutplate itself? Or should I just move on with the installation of the SB kit?
Thanks for your thoughts.
Ian Heritch
RV-12 N417E
AirHound 02-28-2018 07:03 PM
Ian, which method did you use to disconnect the cables?
MrSparkle 02-28-2018 07:16 PM
Doug, if you are asking about the stabilator control cables, I simply unbolted them, which was not too difficult. Reattaching may be a different story.
Ian
MrSparkle 02-28-2018 07:21 PM
Magnaflux Dye Penetrant Kit Available
SOLD
Magnaflux dye penetrant kit SK-416 purchased for SB 18-02-02 for sale in the Classified forum.
Ian Heritch
RV-12, N417E
AirHound 02-28-2018 07:28 PM
Thanks Ian, what did you use to strip the paint off? Sorry for these basic questions, I didn?t build mine. Your photos below are a challenge to interpret if they are cracks or not. Can?t wait to hear what the pros respond with. Soon we hope!
MrSparkle 02-28-2018 07:47 PM
Doug, fortunately I did not have any paint to remove as the front spar was never painted. The red residue you see in my photos is from the dye penetrant.
Ian
rsipp 02-28-2018 08:17 PM
Ian, I'm certainly no expert but those marks all appear to be tooling or chip marks from a counter sink.
RFSchaller 02-28-2018 08:24 PM
I had a really tough paint to remove. I went to Home Depot and asked for their strongest stripper to deal with polyurethane paint. Works pretty well, but you have to use several applications. On the up side I don?t worry about the effects of a gas spill on the paint anymore!😁
rvbuilder2002 02-28-2018 08:36 PM
Just scratches in my (un-official) opinion.
BigJohn 03-01-2018 05:23 AM
Originally Posted by AirHound (Post 1242924)
I’m not the builder. Just thinking through the steps and early comments. Some posts indicate different kit contents, one or no clips, etc, and a couple pioneers indicate different HS removal process steps from sb steps ie; removal of HS horn cables rather than loosening cable adjusters. Perhaps the clips are not necessary and not intended if strict sb steps are followed, therefore the inconsistent amount of clips supplied - as in not really needed. Question I don’t want to hassle with the turnbuckles if the HS horn cable disconnection step in the sb is practical. Specifically, what makes one chose one way to deal with the cables or the other. I’m waiting on parts just trying to understand others comments and make best choices. Thanks! Doug in IL
Doug, I dont see that you got an answer to your questions. The removal and reinstallation of the HS can be a little tricky if you havent done it before. It is pretty hard to describe in text. I would be glad to try and help you if you want to give me a call at 518-774-4898. John
AirHound 03-01-2018 06:20 AM
Thank you Big John and all others willing to help non-builders keep all those fuselage placards shinny.
pilotyoung 01-12-2019 03:33 PM
SB 18-02-02
I getting ready to do this Service Bulletin on my airplane. I didn't see any discussion about painting the parts and matching the color of the aircraft paint. My airplane is painted with Jet Glo Chrome. That paint is not available in rattle cans. I don't have a spray gun and have never tried to spray anything like an airplane.
So how did you guys paint these parts that show after the mod is done?
thanks.
BigJohn 01-12-2019 04:09 PM
I can only tell you what I did. Took a part from my airplane that was painted in original color to a few stores, and bought a can of the best match I could find. Painted the parts before installing them. The part of them that shows is quite small. I can see the difference, but I doubt anyone else would ever notice.
Piper J3 01-12-2019 05:05 PM
There are companies that make custom paint spray cans for almost any type of paint. Search the web.
Try here... https://spectrumpaint.com/customspraypaint/
pilotyoung 01-12-2019 09:38 PM
SB 18-02-02
Thanks for the suggestions on paint. I appreciate it.
Tony_T 01-13-2019 08:14 AM
I did the same as BigJohn and found a rattle can paint that was close enough. Doesn't match exactly but the part is small and will not be noticed unless pointed out.
You'll need to trim the opening in the fairing for the new piece. I took the trim line all the way back rather than just make a notch. If you are careful you probably don't need to touch-up paint that work.
After all the SBs, I named my 12 "Patches".
DHeal 01-13-2019 09:13 AM
A little tip: Before you remove the two fiberglass rear fairings, temporarily position the four (two upper and two lower) small reinforcement plates so that you can mark the portions of the fairings that need to be trimmed away.
NinerBikes 01-14-2019 10:47 AM
Is this modification for older RV-12's now standard with the 2 parts added to the RV-12 iS kits during assembly?
Crafting N112DR 01-14-2019 12:00 PM
Yes the gusset are the same on the original 12 and the 12iS. The part that is different are the way the upper and lower horns are mounted to the spar. It?s a totally different set up using new designed brackets that are riveted instead of bolted.
jetset44 03-09-2019 11:41 PM
Misaligned holes?
First-time poster here. I have a pre-iS empennage kit and am installing this service bulletin during the build instead of retrofit. I just clecoed the HS-01231C gussets into place on the HS spar (Step #22) and found the holes in the gusset don't align well with the matching holes on the inboard hinge brackets. Both left and right brackets and top and bottom are all out of alignment similarly. See the attached photos below. Did anyone else have this problem or have any suggestions? Help would be appreciated!
Steve
rv9builder 03-10-2019 12:21 AM
There are two versions of the HS-01231C gusset. It's possible you received the wrong one for your kit. See this thread for more information, especially post #18 and 22. http://www.vansairforce.com/communit...d.php?t=168001
Mich48041 03-10-2019 07:34 AM
Steve (Jetset44),
Welcome to VansAirforce
jetset44 03-10-2019 11:58 AM
Thanks for the tip, RV9builder! I searched VAF for info but missed that thread. I didn't realize there were two versions of that gusset, but it appears I have the correct one. Looks like a call to Van's tech support is in order...
Thanks for the welcome, Mich48041! Been lurking here for over a year but just now posted.
