Jim |
HS stab removal process
I?m not the builder. Just thinking through the steps and early comments. Some posts indicate different kit contents, one or no clips, etc, and a couple pioneers indicate different HS removal process steps from sb steps ie; removal of HS horn cables rather than loosening cable adjusters. Perhaps the clips are not necessary and not intended if strict sb steps are followed, therefore the inconsistent amount of clips supplied - as in not really needed. Question I don?t want to hassle with the turnbuckles if the HS horn cable disconnection step in the sb is practical. Specifically, what makes one chose one way to deal with the cables or the other. I?m waiting on parts just trying to understand others comments and make best choices. Thanks! Doug in IL
Are these cracks or scratches?
I've been unable to get guidance as to whether what is shown in the following five images are cracks or scratches.
Whatever they are, they are tiny and as you can see they are super close to the rivet's manufactured head. If they are cracks, do I drill a hole so close to the rivet; and when the drill bit works through the spar web won't it then bite into the rivet's shop head, or the nutplate itself? Or should I just move on with the installation of the SB kit? Thanks for your thoughts. Ian Heritch RV-12 N417E ![]() ![]() ![]() ![]() ![]() |
Ian, which method did you use to disconnect the cables?
Doug, if you are asking about the stabilator control cables, I simply unbolted them, which was not too difficult. Reattaching may be a different story.
Ian |
Magnaflux Dye Penetrant Kit Available
SOLD
Magnaflux dye penetrant kit SK-416 purchased for SB 18-02-02 for sale in the Classified forum. Ian Heritch RV-12, N417E |
Thanks Ian, what did you use to strip the paint off? Sorry for these basic questions, I didn?t build mine. Your photos below are a challenge to interpret if they are cracks or not. Can?t wait to hear what the pros respond with. Soon we hope!
Doug, fortunately I did not have any paint to remove as the front spar was never painted. The red residue you see in my photos is from the dye penetrant.
Ian |
Ian, I'm certainly no expert but those marks all appear to be tooling or chip marks from a counter sink.
I had a really tough paint to remove. I went to Home Depot and asked for their strongest stripper to deal with polyurethane paint. Works pretty well, but you have to use several applications. On the up side I don?t worry about the effects of a gas spill on the paint anymore!😁
| All times are GMT -6. The time now is 04:48 AM. |
