Wow, those guys are fast!
Hey Skunkworks, Thanks for the visual. Did you loosen cables in the process couldn?t tell. Or, just detach at the HS horns? Does that table adjust for absolute fit or just stuff a magazine or something to align? Thanks again!!
I?ve done two so far and did not loosen the cables. Using the table, you might have to nudge the hs a little up or down when installing but works well and keeps the fuselage from getting scratched. I did my own using the table with no help whatsoever. You could use other stands, props,etc. having a stand that rolls is a big help.
Dave12, very helpful, thank you.
Got mine done yesterday. 900 hours on plane no cracks found. I went ahead and installed the upgrade. The task is not as bad as it first appears. Vans did a good job designing this upgrade it really adds strength to that area. In the homebuilt world your really never done building.
Thanks to Vans for catching this and providing a fix at a reasonable cost. Gone undetected this could have been a serious issue. Brad Stiefvater Salem SD N124BJ First customer built RV 12 to get Airworthy and Fly |
ME TOO - -
Just finished an hour ago. Was able to pull on cable enough to get hooked up again. Not easy, but doable. Agree, it certainly strengthened the hinges. Getting the two main bolts back in is not a fun job. Getting thin washers in place and pushing bolts in to hold them is a challenge. The new gussets make it even harder to get fingers into the area. No signs of any cracks. 1,185 hours.
PM sent. JohnRussell |
I haven?t got to thes skin doublets yet. Would it be easier to put the stabilator back on and then install the skin doublets?
Hmmm --
Don't think you could. Solid squeezed rivets would be hard to do. Flange to rivet to would still be there. I better say no you can't. Having smaller hands will help. Just not a fun job.
just finished today. Not mentioned in the instructions is the potential for interference between the top tailbone fairing and the gusset at full displacement of the stabilator. Mine did interfere and I had to file an eighth of an inch of the fairing above the gusset.
Hate putting those two bolts in. No cracks, but only 150 hours. N72DJ |
| All times are GMT -6. The time now is 04:47 AM. |
