VAF Forums
-   Glass Cockpit (https://vansairforce.net/community/forumdisplay.php?f=35)
-   -   G3X Touch V5.70 with GMC 507 Support (https://vansairforce.net/community/showthread.php?t=157633)
N96TJ 04-03-2018 09:27 PM
I saw a significant new delay in map redraw for some map features with V5.70, enough so that I thought the software had frozen up at first. It did not seem nearly as bad in V5.90 although I don't have much time on the newer version yet.
g3xpert 04-19-2018 03:52 PM
Hello,
We wanted to give you an update that we have been able to identify and correct the issue that was causing the map drawing delays that several have reported in V5.90 software.
We are working on one additional improvement that we would like to get into the software related to the above report of flashing lights on the GMC 305/307 before we release V6.00.
Thank you for your patience,
Steve
Planecrazy232 06-12-2018 07:11 AM
Any update on the v6.0 software? I'm still having the occasional flashing lights. Also, when I choose NAV it will not engage the magenta line. Sometimes both the NAV and HDG lights will be lit at the same time and I have to toggle back and forth until it will grab the NAV line.
g3xpert 06-12-2018 08:26 AM
Hello Anthony,
We expect V6.00 to be released within the next week. We apologize for the delay.
Most of what you describe is normal autopilot behavior. If your active lateral mode is HDG and the plane is not close to and on an intercept path with the course line, when you press the NAV button on the GMC, NAV mode will be armed, but not active.
Simply turn the aircraft with the HDG knob to put the aircraft on an intercept path with the course line, sit back, and watch the autopilot automatically capture the course line (NAV mode moves from armed to active and the HDG light goes out) when the aircraft is close to intercepting the course line.
Steve
g3xpert 06-15-2018 02:29 PM
V6.00 Now Available
Hello,
G3X Touch V6.00 is on our website now.
Thanks again for your patience.
Steve
KeithB 06-16-2018 07:02 AM
After the issues with V5.7 (albeit minor), we are all a little less willing to be the guinea pig on a new release - especially a primary one ending in .0. However, I?m less than a week from a 4 week jaunt to Alaska and so I?m doubly shy.
Any PIREPs on this release (absence of problems and/or observations on new features) would really be appreciated.
hgerhardt 06-16-2018 07:45 PM
Flew once with 6.0 yesterday and the map redraw is definitely faster, although still not stellar. But, it's been so long since pre-5.70 that I can't remember if it's the same as it was before or not. Haven't tried AP performance, so no comment there. Yet.
Walt 06-16-2018 08:09 PM
About 1.5 hrs today with 6.0, most of the flt with the AP driving, multiple approaches using all modes, 0 issues.
Spirko 06-17-2018 08:15 AM
The AOA/stall warning tone has been intermittent on my system. I see "Improve AOA/stall warning tone output" in the changes to v6.0, is this likely to make tone reliable?
bkthomps 06-17-2018 01:35 PM
what features constitute a major release for version 6.0?
It looks like mostly small improvements, are there any systems or modules that have received a rewrite?
